| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I took the truckout last night for a last ride before I prep for paint and spray on some color.
I was looking around for my sanding block and foud a old sanding sponge. I bought it many years ago to sand drywall and it was a disaster. I don't know why I kept it all these years but the prep gods smiled on me as I tried it on my truck last night.
It was alost enjoyable to use on the primer and the painted areas of the truck. It leaves a nice smooth finish, no wrinkling of the paper to cause scratches or grooves. It is easy to hold onto and control. And it seems to last for a very long time. I sanded for a few hours last night and the sponge still seems to have the same abrasion level.
One side is a little more abrasive than the other. I am going out tonight to see if I can get more. I have seen these at Home Depot (where I bought this one 20 years ago).
I will post type and manufacturer if anyone is interested.
RB53 | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | RB53, I've used these on a fair amount of autobody work with good results and you can usually catch them on sale. Everything goes on sale at HF eventually. Have fun and good luck Dan | | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | Do you know what grit is on the sponge?? If not, you may be in for a lot of resanding. Typically these sponges are a 180 or 220 grit, which is much too coarse to apply your finish coat over without showing a lot of sand scratches. For a urethane finish, the coarsest I would use is 400 wet or dry paper.
| | | | | Joined: Apr 2008 Posts: 95 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 95 | Nice that you are enjoying it. Be aware though, that because these pads are soft and spongy, they will conform to the surface irregularities in the paint/body and will not help to flatten out imperfections as a standard sanding block would. Have fun. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Wally,
That's very true. My painting skills leave a lot to be desired. I am using these to cut the rough finish on my primer. I will switch to 400 with real sanding block once I get a little closer to smooth.
