0 members (), 118 guests, and 1 robot.
Topics128,113
Posts1,056,619
Members48,450
Any of you stepside guys not using the internal brace bars on your step side rear fenders?
I don't have them installed on mine but the fenders seem rock solid. Now I am questioning if I really need them?
Having done some extensive modifications to the bed on my C10 short stepside to accomodate 33x12x15 rear rubber I don't think I will have proper tire clearance if I use them.
Thanks gang!
I'm still running mine, assuming their main purpose is to eliminate stress related metal fatique. I think it might be a good idea to make some custom braces, especially with your setup - as it may be likely to create far more torque and vibration than the original setup. Perhaps rather than a straight rod from the frame, a curved strap against the fender similar to the front fenders of a 1930's Ford for example.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Markeb,
I have a Model A and I know just what you are talking about... small world, eh?
I also was hoping to get some input from anybody out there that isn't running the braces... just to see.
