3 members (Samantha, UtahYork, Stovebolt48), 107 guests, and 3 robots.
Topics128,049
Posts1,055,637
#57193 03/01/2006 6:13 AM
I'm ready to hook up the fuel lines on my truck. I switched from the original Rochester carb to a Carter YF when I rebuilt the motor. I'm trying to keep the factory look, so I'll be going with metal lines. I can buy the line from the pump to carb, but it would be bent and sized to go into the front of the old Rochester carb. Can I just buy steel fuel line in bulk, and are the fittings just a single bend flare?
I figure I could make the bends with a tubing bender.
#57194 03/01/2006 11:16 PM
Riding in the Passing Lane
Yes buy a steel brake tube long enough. Bend it to the right angles & cut off the excess. Double flare the cut off end.
1972 Chevy c10 Cheyenne Super
#57195 03/02/2006 12:29 AM
I do the same as WBR
I buy what ever length in steel brake line (8'' - 51'')(3/16'' - 1/2''dia) and cut the end @ the carb end and use a hose to the carb. My fuel pump has a 5/16'' double flare fitting already.
Remember to place a good inline filter under the truck. I believe it's better there b4 the pump and easy to change, than around the engine where if the hose leaked could cause a fire. Don't use a glass one.
use a double flare fit.
Jim & Caroline
#57196 03/04/2006 10:58 AM
I'm planning to use a remote spin on oil filter base with a filter my FLAPS says is for gasoline and fits in place of a PH8A filter. It costs cabout 14.00;I know that's a lot of money for a fuel filter,but this is a big filter.I figure to bolt it to the frame where the fuel line makes the turn to go from the tank to the fuel pump.I don't remember the part number of this filter,but when I get it,if you're interested I'll post it. just the thing for these old 'bolts with half a tank of mud.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#57197 03/04/2006 2:49 PM
Very good idea. I always put a filter between the tank & pump. But you still should have a small filter or screen near the carb.
