| | | Forums66 Topics128,137 Posts1,056,437 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | any sugesstions on the best way to clean up an Offenhauser 2-1"s intake manifold? Don't want to stain it with the wrong chemicals | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | you could try media blasting it.I have cleaned up aluminum small block chevy intakes this way,they look like new when done.
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Whats it got on it, normal engine dirt or something else?
Simple Green or Castrol Degreaser both work pretty good, glass bead blasting also works very.
Joe | | | | | Joined: Aug 2009 Posts: 36 New Guy | | New Guy Joined: Aug 2009 Posts: 36 | I'm in the process of cleaning up an intake setup myself. This one I've had for over 25 years, used to run it on my '57 chevy 2door HT but it has been siiting (and getting grungy) for the last 20 years or so. I soaked the intake in a 5 gal pail of diluted muriatic acid (hydrochloric acid, same thing). The intake is too long so I just soaked one end until I was satisfied then flipped it over. Works great on cast iron also but you need to neutralize the acid after done. I first power washed the parts then soaked in a pail of water with baking soda in it. Stir often, then power wash again. Here's a before and after. http://www.telusplanet.net/public/tetachuk/intakebefore.jpghttp://www.telusplanet.net/public/tetachuk/intakeafter.jpg | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Semi trailer companies sell aluminum brightner. We spray it on our trailers with a bug sprayer and then wash it off with a pressure washer. Its only something like $12 a gallon. If you don't have a pressure washer, you can just brush it off and wash it off at a car wash before it dries. | | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | thanks for the tips. I like the idea of the muriatic acid ( only because I have some ) what ratio did you use ---water to acid to dilute it and what did you use on the carbs. came out nice looks good thanks | | | | | Joined: Aug 2009 Posts: 36 New Guy | | New Guy Joined: Aug 2009 Posts: 36 | It doesn't really matter what the rate is, the sronger the acid, the shorter soak time. I also used the acid on the carbs (totally dissassembled of course). It cleaned them up real well but didn't get the bodies the way I wanted so I powder coated them. The cast iron throttle bodies are blued/blacked with 44-40 cold gun blue. This stuff requires a good soda soak or they will rust.Always add acid to water not the other way around. Caveat on the carbs, I haven't run them yet so any adverse affects from acid bath or powder coating are as yet unknown, but I don't expect any. | | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Go easy on the acid, try a little at first then add to it if its not working. If you see a lot of bubbles, it to strong. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | The tough part on the Offy dual carb intake is the machined part where the Offenhouser logo is. An acid will dull that too. I have used carb cleaner on mine but it has never really been dulled and dirty. Good luck, I would use weaker chemicals to start and work up until you find what it takes to get it cleaned like you want. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I had an aluminum fuel tank soda blasted, left a nice satin finish not as harsh as glass bead blasting.
Grigg | | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | just finished the intake and exhaust headers. I bought a little container of that stuff called CALYX. So far in this entire restoration that is the most amazing product I have come across!!It's so easy to use and the results are incredible. The headers came out so good I decided to try it on the intake after the acid bath. I don't know how it will hold up but right now they look fantastic! The best thing I found for applying it was an old electric toothbrush (no not mine --- my wifes) the look on her face was priceless when she came out to the garage and saw me working the intake with it. If I've learned anything about this restoration it's that 90% of the work is in cleaning and degeasing the old stuff and only a few minutes to reassemble the piece. Thanks for the help---wes | | |
