5 members (arustycars639, DennisM, homer52, UtahYork, mick53), 100 guests, and 4 robots.
Topics128,268
Posts1,058,394
Members48,485
Getting smoke from either headlight switch or wiring under dash when putting on headlight switch. With switch off ..no smoke.. I know this is a dumb question. How do I find out if switch bad or loose /bad wires
need some more info Charley. what kind of truck? 6v or 12v (are you running 12v through a 6v switch?) Find the problem before you turn it into a smoker or throw a turkey on the seat first.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
If the wires got hot enough to smoke you should be able to see the damage. There's nothing in the switch to smoke. And the switch doesn't care what voltage.
Isn't there a rheostat for dash light illumination in the light switch? When those get full of mouse poop, dust and other debris they act just like a toaster burning toast.
Stuart
hey Cletis, are you saying my original switch is heavy-duty enough to run my all new 12v system? that would be nice to have the original headlight switch in there.
1953 Chevrolet 3600
monster - 6V hardware and wiring are 'heavier duty' than 12V, no worry in keeping the original switch
Isn't this right, 6 volt carries twice the amperage as 12 volt to do the same amount of work? or something close to that?
Thats why you need large battery cable with 6V and why all the other wires will work with 12 volts.
Joe
That's right. Only 6 volts but tons more amps. You can still burn stuff up with 12 volts though. I threw a 12 volt battery in my tractor & burned out 2 coils before I knew what went wrong. Plus the starter nearly tore itself apart. The switch should be fine, but other stuff can't take it.
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
Found problem tail light wire causing short.
old wire worn and touching frame. Did replace switch, it was old and rusted. Will need to replace wiring in the future, but for now, everything is 'good'
12v..I like the turkey idea...Fixed problem..loose wire touching body of truck..worned ...
THANKS...FIXED PROBLEM..LOOSE / WORN WIRE ON TAIL LIGHTS...
REPLACED SWITCH (TEMPORARILY) WITH NEW PULL-PUSH IN-LINE 15 AMP FUSE SWITCH ($3.99)..REPLACING ALL WIRES ONE AT AT TIME. WHEN FUSE BLEW..THIS IDENTIFIED WHICH WIRE..(TAIL LIGHT)
