1 members (J Lucas),
40
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57041 02/25/2006 4:18 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I’m closing in on the welding phase of my attempt at exhaust manifold splitting. I have been taking pic’s along the way and now have them up. Any knowledgeable input on the front/back position of the extra outlet as well as flange orientation is appreciated before I carry on. I’m going to have the welder do the blockoff plate in the front pc, and then I’ll do an L.P.I. before attaching the front outlet. http://community.webshots.com/album/547970017qahQTi Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#57042 02/25/2006 4:28 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Man, that looks great. Nice shop BTW. I have a split mani in my truck and the split is on the other side of the heat plate. Yours may work a little better because it will not interfere with the accelerator linkage. Hope it works out for ya.  | | |
#57043 02/25/2006 4:54 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | WOW!!!! This is a great pictorial and prime material for the 'Tech Tips' section!!!! 3 thumbs up! | | |
#57044 02/25/2006 4:55 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Curt, what is that elbow from? | | |
#57045 02/25/2006 6:22 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Thanks. The elbow is a 90 deg heavy wall 2" i.d. steel pipe. Under $5.00 at a steel supplier. The flange is carved out of 3" x 3/4" flatbar. I'm spoiled with all the right tools at hand ... It took about 15 seconds to cut the manifold.
#57046 02/25/2006 7:55 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | | | |
