7 members (Bill Hanlon, Oswald, elhippie64, moparguy, 1955 1 Series, Southerntruck, 1 invisible), 99 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
#57027 02/24/2006 11:06 PM
Hi everybody, I'm in the process of gathering the pieces to install a 55 car 235 in a 59 Apache. I've done this swap years ago and seem to remember the truck thottle linkage is different from the car linkage. I have the truck linkage from the pedal to the bellcrank on the engine. Is the rest of the linkage (bellcrank, and linkage to carb) unique to a truck? If so, does anyone have the truck linkage they are willing to part with?
Thank, John
I'm sure a lot of you know the answer to this so why noit chime in and help him out?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
hmmm ok, remember a question like this and thought it'd been answered - the linkage that's mounted on the engine is the same grin
2 Offline
You can always make your own linkage with a 1/4in. rod. Just bend it to fit.
I
I Offline
I can't seem to find it now, but a while back I came across an artical about engines having the casting hole on the side in a differnt place. Seems like it said that the 261's hole was a little further back on the block. If this were true then the linkage would be shorter or longer some place.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
Throttle Pivot Positions
216s, 12 9/16” from rear of block.
1953-59, 9 1/8” & 12 9/16” from rear of block.
1960-62, 9 1/8” only, from rear of block.
My Blog
Here is a link to a picture showing the side of a 261 engine.You will notice that the hole is inbetween the two freeze plugs,closest to the left freeze plug.Keep in mind the block is upside down.Hope this might help.
http://img128.imageshack.us/img128/9659/sideof261block6dh.jpg
1951 3100 Chevrolet
It looks like your block has both pivot points.
My Blog
