1 members (Guitplayer),
104
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57027 02/24/2006 11:06 PM | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | Hi everybody, I'm in the process of gathering the pieces to install a 55 car 235 in a 59 Apache. I've done this swap years ago and seem to remember the truck thottle linkage is different from the car linkage. I have the truck linkage from the pedal to the bellcrank on the engine. Is the rest of the linkage (bellcrank, and linkage to carb) unique to a truck? If so, does anyone have the truck linkage they are willing to part with?
Thank, John | | |
#57028 03/03/2006 7:30 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I'm sure a lot of you know the answer to this so why noit chime in and help him out? | | |
#57029 03/03/2006 8:04 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hmmm ok, remember a question like this and thought it'd been answered - the linkage that's mounted on the engine is the same Bill | | |
#57030 03/03/2006 9:35 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | You can always make your own linkage with a 1/4in. rod. Just bend it to fit. | | |
#57031 03/05/2006 3:45 AM | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | I can't seem to find it now, but a while back I came across an artical about engines having the casting hole on the side in a differnt place. Seems like it said that the 261's hole was a little further back on the block. If this were true then the linkage would be shorter or longer some place. | | |
#57032 03/06/2006 2:01 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Throttle Pivot Positions
216s, 12 9/16” from rear of block.
1953-59, 9 1/8” & 12 9/16” from rear of block.
1960-62, 9 1/8” only, from rear of block.
See the USA in your vintage Chevrolet! My Blog | | |
#57033 03/06/2006 2:29 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Here is a link to a picture showing the side of a 261 engine.You will notice that the hole is inbetween the two freeze plugs,closest to the left freeze plug.Keep in mind the block is upside down.Hope this might help. http://img128.imageshack.us/img128/9659/sideof261block6dh.jpg 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#57034 03/06/2006 4:08 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It looks like your block has both pivot points.
