2 members (Rusty Rod, baldeagle), 91 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#56994 02/24/2006 4:45 PM
I'm trying to find the EXACT year of the 235 engine in my 56 3100 (I have a post in General Truck Talk as well)
According to www.inliners.com the block casting number (3769716) puts it as a 58-62.... then it has a stamped number (F0301BE)... according to the coding info at the American Classic website the "BE" is listed under 1960 as an engine with a Power Glide tranny (I have a 4 speed)....
So a couple of questions:
1) Do I in fact have a 1960 engine?
2) Did trucks come with Power Glide trannies? Or do I have a car 235 with the original 4 speed?
3) Does the engine have hyrolic valves?
Thanks Stovebolt Wizards!!!
Larry Bear
55.5 Chevy 3100 Panel
#56995 02/24/2006 5:11 PM
Larry, the numbers don't lie! looks like someone replaced the engine, and it originally came from a 60 car - not suprising the ol thing got a heart transplant along the way grin
prolly does have hydraulics as the auto car engines did have'em - hafta check it out and see
#56996 02/24/2006 5:22 PM
Thanks Bill!
Is there anywhere I can go to to de-code the stamped id#?
Larry Bear
#56997 02/24/2006 6:45 PM
don't know a place on the net right off other than Amer Classic, but there are books that have lists of those codes - the F will be the Flint plant, and as the BE seems to indicate car model and trans combo, the numbers may just be a date code
#56998 02/24/2006 7:50 PM
American Classic only makes reference to the "BE" part but not the rest of the numbers. And inliners.org only has casting numbers.
I think you may be right about the numbers indicating dates tho, Bill.
Anyone else have any ideas?
Larry Bear
#56999 02/24/2006 9:35 PM
The 1960 Chev parts book shows "BE" as a 1960 passenger car 235 with Powerglide and Power Steering.
My Blog
#57000 02/24/2006 9:56 PM
Mmmmm.... thanks Dave! That confirms what I've found out. Is there any mention about the other numbers?
The stamped engine number is F0301BE... I understand the "F" is "Flint"... so now just trying to understand the "0301"
Thanks!
Larry Bear
#57001 02/24/2006 10:06 PM
too bad it didn't include the power steering pump! grin
most likely march 1, [1960]
#57002 02/24/2006 10:22 PM
My guess is that the original PO, a Colorado farmer, said "I don't need no stinkin power steerin!"
Actually, since I redid the king pins she ain't all that bad!
Larry Bear
#57003 02/25/2006 1:46 AM
X
X Offline
BE is for the '60-'62 passenger car 235 with PG and PS (which would have hyd. lifters). The other numbers are the engine build date (0301=March 1). No exact year is given in the serial number. To pinpoint the year, look for the block casting date code on the block near the starter. This code is a letter followed by two or three numbers. The last digit of the date code is the last digit of the year. The build date is usually a few days after the casting date.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#57004 02/25/2006 3:12 AM
I could be wrong but I think 1960 was the last year that the 235 had front motor mounts. That may help??? I'm not sure but I'm sure someone will tell me if I'm right?...or if I'm wrong!!
#57005 02/25/2006 12:01 PM
Thanks for the continued info guys - we're narrowing it down for sure!
Curt: Can I presume that the engine code info on the American Classic site is correct? If so, then they only list the BE under 1960 and not 61 or 62. So for the stamp id F0301BE it appears as if I have an engine made in Flint on March 1, 1960... correct?
I'll have to check on the other block casting number you're talking about... I do have a block casting number that's on the pass side: 3769716 that tells me that it's a 58-62. I didn't know there was another casting number.
Larry Bear
#57006 02/25/2006 6:07 PM
X
X Offline
Larry:
I've found that some of the code info on American Classic is incomplete, or sometimes just wrong. Their engine code lists for '61 and '62 only show codes for the truck engines, so your car engine code is not included.
The suffix lists in my Chevy parts manuals show the BE suffix for '60, '61, and '62. The only way to narrow it exactly is by the block casting date code, which would give the year, as mentioned above.
BTW, not that it matters, but your engine could have been installed originally in any of the car models, excluding Corvair of course (1100, 1300, 1500, and 1700 series 6-cyl. vehicles--Biscaynes, Bel-Airs, and Impalas). The serial suffix doesn't specify the exact model.
Curt
#57007 02/25/2006 6:08 PM
The date the engine was cast is right above the starter. It is in code so post it and we can explain how to decode it for you.
My Blog
#57008 02/26/2006 9:06 PM
Thanks guys!
I'm a tad dense so forgive me for asking so many questions! I'll look for another casting number.. the one that I have is from the pass side (3769716) but I'll look on Tuesday when I'm at the garage and see if there's another one.
Meanwhile, the info I got from American Classic about the STAMPED ID is from: http://www.americanclassic.com/paint.htm?p1=engines
and that shows a "BE" as 1960... but maybe I'm interpreting it wrong.
Larry Bear
#57009 02/27/2006 8:29 PM
Larry, the casting date is a raised casting on the pass. side of the block above the starter. It is not a number stamped on the block surface. should look somthing like this.
C 3 0 or B 18 3
Hope this helps
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#57010 02/27/2006 11:04 PM
I hear ya but, I do in fact have TWO different sets of numbers... one is the stamped number (F0301BE) and the other is a cast number (3769716)..... I don't think the 56+ years didn't have letters like you say.... I'll look again for any other numbers but I think what I have is indeed the casting number... but I'll check.
Larry Bear
#57011 03/01/2006 1:00 PM
Here's what I found last night at the garage...
There is only ONE casting number on the block: (3769716) near that number there IS a "GM" with a smaller either "18" or "1B" below the GM. That's it there are no other numbers/letters near the starter.
The stamped number is on the plate: (F0301BE)
That's it. No other numbers. Based on what I've been able to gleen from the various sources and help here I'm pretty convinced it's a 1960 235 from an 1100 series vehicle.
Based on that, we went ahead and adjusted the lifters as hydraulics and she's running better now.
Larry Bear
#57012 03/01/2006 8:42 PM
*Bump*
Larry Bear
#57013 03/01/2006 10:40 PM
The date code looks a little different and it may be behind the starter. All I have seen also have 2 slotted screw heads cast in as well. I think the date code was on a metal strip that was screwed to the mold. It's got to have it.
Professional Novice
#57014 03/02/2006 3:33 AM
My 53 has a 59 235 in it. There are three numbers on the block that give information. First, the casting number is located on the front half of the passenger side, down near the oil dipstick. The casting number 3764476 is a 58-62 Chevy 6. The casting date is on the rear half of the passenger side, (as Frank50 says) behind the top of the starter (can just barely see it with the starter in place). The casting date is D229 which corresponds to a casting date of April 22, 1959. Finally, the assembly date is engraved (or stamped) on the flat boss behind the distributor. The assembly date number is F424A which breaks down to Flint, MI assembly plant, assembled on April 24, and is a type A. Type A was a 235 6 cylinder engine with standard transmission or overdrive and standard duty clutch. Used in passenger and delivery vehicles.
If all of my research and decoding is correct, they must have been churning out those trucks, the engine must have been still warm if they were assembling it two days after it was cast. grin
I think if you take off your starter and clean up the block behind it, you will see the casting date.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#57015 03/02/2006 2:06 PM
THANKS JEFF! That's great very specific info... This is the first time I've heard about a specific place for another number... I'll check.
Larry Bear
