1 members (Southerntruck), 98 guests, and 6 robots.
Topics128,266
Posts1,058,386
Members48,485
#568902 08/27/2009 3:26 PM
geb
Offline
Apprentice
Apprentice
I have a 1950 216 all stock, the ignition coil I have seen mounted up and down, what is the stock position for the coil. Thanks
The wires on the coil should be facing down.
Many people mount them with the attachment posts up, for ease of attachment (and, I've heard people say, to avoid leaks)? If the coil leaks, replace it.
All documents that I have seen have had the attachment posts down.
geb
Offline
Apprentice
Apprentice
Thanks for the quick responses, Have a great day
Stock is down, but I did have my coil wire fall off once. But clearly because it was not fully pushed in, because it hasn't happened since.
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
Before I re-built the 216 the coil was facing down. After the re-build the coil would not fit facing down, so I had to flip it over. All I can figure is that I pushed the oil pump in too much, causing the distributor to raise up a little when I installed it.
