10 members (DadsFirstPickup, 5 Window 9434, TrknGMC, Guitplayer, 3800GUY, Woodcmiami, KCMongo, Shade Baby, 2-Ton, 1 invisible),
121
Mod | | | Forums66 Topics128,049 Posts1,055,662 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 14 Apprentice | | Apprentice Joined: Apr 2008 Posts: 14 | I have a 1950 216 all stock, the ignition coil I have seen mounted up and down, what is the stock position for the coil. Thanks | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The wires on the coil should be facing down. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Many people mount them with the attachment posts up, for ease of attachment (and, I've heard people say, to avoid leaks)? If the coil leaks, replace it.
All documents that I have seen have had the attachment posts down.
| | | | | Joined: Apr 2008 Posts: 14 Apprentice | | Apprentice Joined: Apr 2008 Posts: 14 | Thanks for the quick responses, Have a great day | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Stock is down, but I did have my coil wire fall off once. But clearly because it was not fully pushed in, because it hasn't happened since. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Before I re-built the 216 the coil was facing down. After the re-build the coil would not fit facing down, so I had to flip it over. All I can figure is that I pushed the oil pump in too much, causing the distributor to raise up a little when I installed it. | | |
