1 members (baldeagle),
36
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Hey Guy's, It's been awhile. I got a problem with my 52 speedometer.It is spot on up to 35 and then starts to get fast. At 55 I'm really doing 45. Once in awhile it also starts to bounce around also. What do you think, speedo or speedo gear in the trany? I have a 3 speed and 16" tires. Thx. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Could be a cable issue in regards to the bounce. The innaccuracy is probably due to the 16" wheels, 1/2 tons were originally spec'd with 15" I think the next wheel choice would have been 17". | | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | What does the odometer read, fast, slow or right on? The odometer is gear driven, so get it to read milage correctly then think about the speedometer.
The speedometer needle is driven off the end of the cable buy a magnet, the matching magnet is hooked to the needle assembly. If the magnets get weak, or the needle assembly gets dirty, it will not read correctly. The odometer will always read what the gears tell it.
joe | | | | | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Uhm, I thought my post was pretty clear. The speedo reads fast after 35. The odometer is weird though. Tens and single miles read fine but teens and above jump out of sequence. Also my drivers and service manuals state the truck uses 16" wheels as standard. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is this post referring to a 1952 1/2 ton Chevrolet truck? 15" standard wheels? 17" next most common choice of wheels? 6.00x16 was base (standard) 15" would most likely have been third most common (after 6.50x16) 17"? 8-lugs, at least for 3/4-1 ton? If the cable is lubricated sufficiently, Joe H's suggestion seems very reasonable. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I have had similar problems in a couple of vehicles. But it was also accompanied by a significant noise from the speedo. You didn't mention any noise. In my case it was the bushing where the cable connects to the speedo. The lube had dried out.
regards, Leon | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | From what you have said, I would think that someone has taken the odometer apart. As far as the error is concerned, what is it like below 35. If it goes to the slow side then you probably have error due to the wrong drive gear ratio. | | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | In general, weak magnets should make it read closer to the correct speed the slower you go. Two things come to mind when the the gauge shows faster then actual speed, one is dirt in the needle head, and the other is wrong gearing in the trans. To know which it is, you must drive a known distance using GPS or highway markers to determine what the odometer shows, at least 10 miles, 50 would be better. Remember, the odometer is a direct reading of the gearing. Dirty cables and fittings should be corrected before testing to insure a smooth operation. Dry lubricant only in the cable, and sewing machine grade oils in the speedometer head. If the odometer doesn't read accurately, correct the gearing or rebuild the speedometer head. http://www.wallaceracing.com/speedo-calculator.phphttp://www.transmissioncenter.net/speedometer_calibration_______va.htmhttp://www.bgsoflex.com/speedo1.html | | |
