4 members (37 GC, Otto Skorzeny, Shade Baby, Eisenholtz), 122 guests, and 2 robots.
Topics128,140
Posts1,056,776
Members48,454
Apprentice
Apprentice
I'm sure it's been discussed but one more time please.....I'm considering putting a small block in my 51 1/2ton. Does the steering box have to be moved??? Is there someone who makes the engine mounts that offset the engine or offset the box?
How about a big block? I've had one in another 51 but it also had a Camaro sub frame.
Tom
1951 Chev.P.U. Streetrod-project
1951 Chev cpe 261 5-speed-50%
1953 Chev cpe 350/700-95%
1962 Chev Bubbletop 409 -75%
I just saw it mentioned that a '55 265 left manifold will clear without moving the steering box. This is second hand info,but sounds like it'll work to me. (If you can find 'em,it might be good to go with a set from a '55,just for synchronicity. {balance})
For a bigblock,I think the subframe is a better idea.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Apprentice
Apprentice
Tom,
check out this website...I checked it myself and it works...
http://www.speedprint.com/Deves50/doc/v8stovebolt.pdf
51 1/2 ton-455 rocket!
49 1/2 ton panel-rocket-to-be!
Thanks for posting that link.
There is lots of good info on that over and above the part on steering.I used that method to move my box out 1 3/4". I don't have an arc welder though so for the top plate I added the width of the frame under the original bolting place of the box and bolted the plate to the frame. It worked excellent.
Lothar
Junior Member
Junior Member
A Chevy 350 cleared my stock steering on my 55 2nd series.
Working on my 55 2nd series to make it a daily driver.
http://www.hotrodders.com/forum/journal.php?journalid=26732&action=view
Well, my next truck will either already be converted or a 55 2nd series or newer. Now I know why I stuck with 55-57 chevies cars all these years , they make working on them a picknick compared to my 53 AD. I think it will be wirth it once every think is finished though.
Has any one ever used the Turbo 350 side mounts for 55-57 pass cars? They work excellent in those cars, so I eyeballed them up in my 53. They looked like they would work perfect, all you'd have to do is drill holes in the crossmember(you cut the center section out of it and weld it back in 2" lower.Then all you'd need is the 57 front mount system and a simple cross member.You wouldn't need the trany mount then because you have a side/front mount system.
