1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56861 02/21/2006 8:16 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | We build a new exhaust setup for the 235 (typical dual Offy/holley-weber/split exhaust/m4F/ .06 over). The pipes are 2 1/4 inch diameter with 2 flowmasters just before the rearend. I was kind of disapointed when I drove it the first time. It feels like it lost all of the low end torque. Is it possible to loose so much torque just by installling bigger diameter pipes? I thought that the lower backpressure the better it is. Thanks, Frank | | |
#56862 02/21/2006 10:09 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | I think 2 1/4" pipes will handle up to 300-400 hp. Your 6 cylinder is making less than 200 (?). Lower back pressure is better up to a point. I am not positive, but for some reason I don't think you should go bigger than 1 3/4". Somebody on this board WILL correct me if I am misleading you.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#56863 02/21/2006 10:49 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like a lot more exhaust system than needed but it shouldn,t hurt anything although I,ll bet it,s really loud. You may be running too lean. With better exhaust flow you need a richer mixture. Also you may not have enough heat to the manifold. The timing could also be advanced a little. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#56864 02/21/2006 10:59 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I go and check timing and mixture.
By the way, I saw in an vintage hot rod magacin a J.C. Withneys ad for a dashboard device to adjust timing "ont the fly" (I think it was made by Almquist) and similar Do-Dads.
Did anyone ever came up with the idea of an exhaust throttle?
I mean something like a choke plate that sits in the exhaust pipe near the header and can be adjustet from the dashboard. Open for high rev performance and more restriction for low end torque?
....probably just an other of mine silly ideas but they offerd all kin`s a stuff back thaen.
Frank | | |
#56865 02/22/2006 12:05 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Yeah Stovebold, and don't forget the magnets on the fuel line and the Turbo air inlet. That out to make another 50 HP, huh?  | | |
#56866 02/22/2006 12:35 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | open up those lake plugs  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#56867 02/22/2006 1:11 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | seems there was a big argument over on Inliners site about a year ago about exhaust diameter, but the gen. consensus was duals bigger than 2" was too much for a six, I believe. brian | | |
#56868 02/22/2006 1:13 AM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Exhaust pressure is very essential on 2 stroke engines but I think a little tinkering with mixture and timing will correct your problem. Don't think you have created a problem with the oversize pipe | | |
#56869 02/22/2006 1:31 AM | Joined: Jul 2005 Posts: 25 Junior Member | | Junior Member Joined: Jul 2005 Posts: 25 | The word back pressure is used a couple of times in this thread.My opinion is there should be little to no back pressure in the exhaust system. The pipe should be small enough to maintain exhaust velocity to help evacuate the cylinder. I think when you went to the larger pipe it probably slowed the exhaust gases down enough to effect low end torque by not evacuating the cylinders as well at low RPM. When the exhaust valve opens the gases escape at a high rate of speed as the piston rises to near TDC the gases start to slow down. If the pipe is small enough or large enough to maintain velocity it will help to pull the remaining gases from the cyl. I also believe that a cam with a lot of overlap and an exhaust system piping to small will lead to over scavaging the cyl.(pull to much of the incoming charge thru the exhaust valve)leading to poor performance. I guess what I am trying to say is the pipe dia. should match the RPM range you want run. My opinions only Arnie | | |
#56870 02/22/2006 2:03 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Amen on that, Arnie. I don't know why so many people think it is the backpressure that improves the torque when it really is the velocity. Sometimes improving the velocity can create a little more backpressure, but the benefit comes from velocity, not backpressure. | | |
#56871 02/22/2006 7:05 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Arnie and Baldy are right. A close friend of mine has one of the top pull tractors in the country and spends not hours but days on his dyno. He sometimes takes my humble advice although the student is now much smarter than the teacher. Here is a description of exhaust function in very common and hopefully easy to understand terms. To visualize scavaging think of the old suction guns used to suck up oil out of the old cannister type filters, when you pulled up the piston in the barrel of the gun it created a vacuum that sucked up the oil. In the exhaust tube on an engine the piston is replaced by a pulse(ball) of exhaust and the faster it moves through the tube the greater the vacuum is behind it. At this point when the intake valve opens and this vacuum from the exhaust helps pull(scavage) the burned gasses from the cylinder and pull in the new air/fuel mixture. Now, if you increase the size of the tube the ball doesn't fit as tight and loses some to much of it's suction so the scavaging effect drops. If the engine can run at a very high rpm then the large tube gives less restriction and though each pulse has less draw there are so many more of them moving at much higher velocity that there is a net gain in power. In a low rpm engine big exhaust tubes will kill low end. I know I've used "vacuum" with license but it is easier to visualize. Now if all this back to school stuff hasn't put you to sleep you can go on to the next thread.
Evan
#56872 02/22/2006 10:01 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | Thanks guys, that makes perfect sense.... .... BOOOO HOOOO! All that work and money for the birds. Well at least a chance to try my new pipe bending machine :rolleyes: would you say that I can keep the bigger pipes from the mufflers to the bumper or would they influence the torque too because the gasses "shrink" when they cool off? Frank | | |
#56873 02/23/2006 12:01 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I think keeping the pipes after the muffler would have minimum influence since the gas has already expanded and slowed in the muffler.
Evan
#56874 02/23/2006 1:12 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | You can make a temporary baffle to block off about 1/3 the exhaust pipe outlet to see if there's any improvement,a piece of sheetmetal and a hose clamp will do it. When you change one thing,it may screw up the engine tuning.Been my experience that the old 6's,once modified,especially with a hotter cam,need more spark advance at mid speeds,like a recurved distributer advance.For a test,simply advance the timing about 10 degrees,road test it.Temporarily over advancing the timing won't hurt anything,just don't run it at full throttle and maxiumum revs. | | |
#56875 02/23/2006 1:36 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | my truck has 2" exhaust. but it is a single pipe, with standard muffler. I notice no bad effects from 2" pipe, it is the same diameter as the old pipe that was on it. I am not sure what to tell ya, sounds like a wierd one to me. maybe you have it over muffled? too much pipe diamter? But I am not really sure. Good Luck.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
#56876 02/23/2006 1:58 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | ft knox, I think he is running TWO 2 1/4 pipes on a 235,brian | | |
