0 members (), 129 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#568544 08/26/2009 6:20 PM
Hello I was just wondering if all the second series frames are interchangeable from 55-59 chevy to gm, short box and long box
1957 chevy 3200
To start with, the entire run was not called second series. There were 2 series of trucks in 1955. The second series was the first of the Task Force Chevrolets and the Blue Chip GMCs.
In US models Chevrolet and GMC frames are different. Canadian GMC trucks used Chevy engines so those may be the same. Also, '55-'57 frames differ slightly in length from '58-'59 frames.
Long bed frames are longer than short bed frames.
I'm glad you pointed that out Cletis. dang
So I could use a 55 gmc frame and bolt all my 57 chevy parts to it with little or no modification.
1957 chevy 3200
The GMC engine is longer so the motor mounts will be different. Not sure on the front sheetmetal/radiator thing.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
If it is a Canadian GMC it would have had the Chevrolet engines so that part should work. I, too, am not sure about "front sheetmetal/radiator thing".
red58 would know for sure, but I'm thinking that there is a difference in the radiator mounting. I know the GMCs have an extra brace that the Chevies do not have that goes from the core support to the firewall.
Bill Burmeister
