1 members (2-Ton),
141
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 10 New Guy | | New Guy Joined: Feb 2007 Posts: 10 | This 1954 3100 was my first vehicle. I've had it since 1974, my Dad bought it around 1956. Dad and I put a 350 & TH350 in it around 1978. In 1992 to save some insurance money I parked it (Big mistake) Got it cleaned up and running recently, took it for it's first road trip this last weekend and she ran great, amazing what a little elbow grease and TLC will get you! I have always wanted headers and picked up a set of block huggers, even with the stock steering box moved as far over as possible they are a no-go. I plan to install a 3" drop front axle in the near future and the old steering box has to go. What is the best manual box to run? and set up? I see power kits all over the place, any manual kits out there? Or advise on what to start scrounging up? Here is a picture from last week end, I'll post more as she progresses. Thanks for any advise. http://i33.photobucket.com/albums/d71/SeaOx/IMG_0166.jpg
salvo
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi salvo...that's a sweet looking '54 you've got. I'm glad you got her where she should be...back on the blacktop. I'm not too clued up on the steering issue as I've gone the Mustang II route, hang tight though, help will arrive just shortly. Good luck. Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2007 Posts: 10 New Guy | | New Guy Joined: Feb 2007 Posts: 10 | Thanks jock! A friend and I got it running a couple years ago, but I got side tracked. Been working on it steady for about 3 months now, been through everything! Planning a trip up to Utah Labor Day weekend, my folks live up there, can't wait to throw the old man the key's and tell him and mom to go take a long drive. It really is nice to have it back on the blacktop.
salvo
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Saginaw makes a manual box. I think you would want a late 60s to early 70s box. They look like a Saginaw PS box, just smaller. They will mount and connect just like a Saginaw PS box. Here is a picture at Rock Auto's site This is a 1970 manual Saginaw box. It would work very well.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Nice truck salvo!! It's good to hear another 'bolt is back on the road.
If this were my truck I'd get a refund on the block huggers and look for a pair of factory ram's horns or other stock manifold that will fit your situation. They'll actually perform better on your stock or mild 350 than the headers and they won't need continual tightening. Should be able to run your stock steering box too.
Just an opinion though, good luck with whatever you decide to do, oh, and welcome to the Stovebolt pages too!!! | | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | Check out a box from a Land Cruser or Tacoma with a straight axle. I'm working on fabing a kit to mount the box forward of the axle by the core support, using a steering colum from a Jeep Cherokee with u joints & a shaft in between. The arm swings verticle just like the stock box.
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
| | | | | Joined: Feb 2007 Posts: 10 New Guy | | New Guy Joined: Feb 2007 Posts: 10 | Great info, thanks! Lonnie Gallaher, what vehicle can that box be found in? I would buy a new/rebuilt but the parts guys I have dealt with are lost without a vehicle to trace the part too, so am I!
waldo53, I have thought about Ram horns, sure would simplify things, I did get a refund on the block huggers. Just something nice about headers.
nvrdone, I actually have a 76FJ40 that I put a big block in and power steering, I'll have to go see if I still have the old steering box out in the garage. I really appreciate the help, you guys have given me some great ideas.
I understand cutting the column, fab a column bearing, shafts and u-joints. What does it take to connect the new box to the remaining linkage?
salvo
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I guess it's safe to assume you've considered the work involved in "dropping in" a new box, changing/fabbing a new pitman arm and modifying the stock or changing the column, shift linkage and electrical. As Waldo53 correctly points out, swapping out a set of Rams Horn headers would be the least painful solution. Headers in general, don't factor in until you get way up in the rpm range.
If you were going to go for a power conversion you'd have to make these changes. I prefer the stock manual box in my daily driver 54 as it is tough, responsive and I get good feedback from various road surfaces. Consider the Ram's Horns...and you'll save yourself a bunch of headaches.
Dave
BTW.....if you need additional clearance you can use a pass side truck Ram Horn exhaust manifold with the outlet pointed forward on the Driver's side.
Dave | | | | | Joined: Feb 2007 Posts: 10 New Guy | | New Guy Joined: Feb 2007 Posts: 10 | Fla54Chevy3100, you have a great looking 54! And enjoyed your updates in the gallery. I'll have to think a little harder about the Rams horn. Tuckers parts is located here in Vegas, I asked them about Rams horns a while back and if I remember correctly, they either have them or can get them for around $100.00 each, I guess that’s reasonable?
salvo
| | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | Right now I have center dump rams horns on my pickup with the steering box moved out about 2". It works well. Check out allamericanclassics.com for a set of rams horns. There phone # is 360-254-8850 in Vancouver WA. Look at there web site. You will be blown away.
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Salvo,
1970 C10 Chevy truck. | | | | | Joined: Feb 2007 Posts: 10 New Guy | | New Guy Joined: Feb 2007 Posts: 10 |
salvo
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I got lucky and a fellow friend gave me a set of Ram Horns and they fit nicely in my 52panel. BOTH of mine have the "built in" mounting place for the gen/alt and the other side can be for A/C.
The reason I mention this is we may be over looking a good source for these ram horn headers. While trying to figure out just what year these headers were another friend of mine said they had the "mounting places" on both sides because they came off a 2 ton truck that had an oil cooler mounted on the passenger side. I do not know if there is any truth to this or not but as info someone might confirm this?? I also believe mine came off a 327 engine. Either way they cleaned up nice and with some Calyx rubbed on them they look nice. Soooo, don't pass up a big truck in the pasture. It may just have what your looking for???? There is a pic of my ramhorns in the photobucket below.
As for steering I finally gave in an put power steering on mine. Bought a rebuilt box for a 74 model year from Advance Auto and got the kit for mounting it with everything but the pitman arm. I think the instructions said use one off a mid year malibu/Monte which I think is 5 1/2". ..... just another thought.
| | | | | Joined: Feb 2007 Posts: 10 New Guy | | New Guy Joined: Feb 2007 Posts: 10 | Great info Achipmunk, I'll keep a look out! Your 52 is looking good.
salvo
