3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
#56832 02/21/2006 5:41 AM
Anybody ever put a SWB Task Force on a Tahoe 4x4 Chassis? The frame is reasonably flat and the IFS with torsion bars looks easy to work around. Haven't bought chassis yet, any one better than others? Thanks
They named it Apache cause it has a patchy welded here and a patchy welded there.
#56833 02/22/2006 8:14 AM
Don't forget to take LOTSA pics. This sounds really interesting! Hope it works out as well as it sounds like it should. (but--do they make a Tahoe with a stick??)
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#56834 02/22/2006 4:43 PM
Take lots of measurements. The track width might be too great on the Tahoe.
If that's not an issue, it sounds like a neat swap. Access to the complete donor vehicle is a big plus. Things like Steeribg collumn, master cylinder, etc are best when obtained on the cheap. I'm with Spedd, "take pictures!" Cheers. MV
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#56836 02/23/2006 7:08 AM
I saw one at a swap meet last year. It had a 117" wheelbase, have to be shortened 3" to match my swb 114. The neighbor works for a towing place and they have a Tahoe fresh from the Mississippi River. Hoping to get my hands on it cheap.
#56837 02/23/2006 10:22 AM
If it turns out to be "too wide",why not use a 1-1/2 ton doghouse on it? Then it'd be just right. And I suspect you can buy over-wide rear fenders for stepsides,cantcha?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
