0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56832 02/21/2006 5:41 AM | Joined: Feb 2006 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 50 | Anybody ever put a SWB Task Force on a Tahoe 4x4 Chassis? The frame is reasonably flat and the IFS with torsion bars looks easy to work around. Haven't bought chassis yet, any one better than others? Thanks
They named it Apache cause it has a patchy welded here and a patchy welded there.
#56833 02/22/2006 8:14 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Don't forget to take LOTSA pics. This sounds really interesting! Hope it works out as well as it sounds like it should. (but--do they make a Tahoe with a stick??) Speed | | |
#56834 02/22/2006 4:43 PM | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | Take lots of measurements. The track width might be too great on the Tahoe. If that's not an issue, it sounds like a neat swap. Access to the complete donor vehicle is a big plus. Things like Steeribg collumn, master cylinder, etc are best when obtained on the cheap. I'm with Spedd, "take pictures!" Cheers. MV | | |
#56836 02/23/2006 7:08 AM | Joined: Feb 2006 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 50 | I saw one at a swap meet last year. It had a 117" wheelbase, have to be shortened 3" to match my swb 114. The neighbor works for a towing place and they have a Tahoe fresh from the Mississippi River. Hoping to get my hands on it cheap.
#56837 02/23/2006 10:22 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | If it turns out to be "too wide",why not use a 1-1/2 ton doghouse on it? Then it'd be just right. And I suspect you can buy over-wide rear fenders for stepsides,cantcha? Speed | | |
