1 members (Uncles51),
105
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I put the headliner in the '49 yesterday, by myself. It was not easy. because they are not cut properly. I probably trimmed a 1/2 inch of each end. A little at a time, hopeing it would not be too much. If they were sized right it would not be a bad job. http://inlinethumb15.webshots.com/42830/2946447520098468599S500x500Q85.jpgAlso see how the after market windlace kinked on the back curve of the door opening. Cleon | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | that looks good Cleon, my windlace kinked about like the little crease in the front on yours, but only one crease. I am hoping it will straighten out with the gentle persuasion I give it each day. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | good job and with only 2 hands.......heck of deal.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Looks good Cleon, often wondered why everyone alway complains about that being such a hard job. Who did you buy your new windlace from??? And what paint did you use on your heater??? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Thanks Denny, I bought the windlace several months ago and can't find the recipt. So I'm not sure which vendor it was. I should have used Steele Rubber. The paint on the heater is Rustoleum Hammmered Bronze. It's not correct but I like it. Cleon | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks, I shot some samples of that and the surface finish is really rough, like the surface of the Moon. I was trying to figure out a way to smooth it out yet still have the hammered finish, just not as strong as straight from the can. http://www.pbase.com/dennygraham/image/116562622 Tried mixtures with different paints and thinning but still not happy. DG
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Denny, This was right out of the rattle can. It laid down pretty well. Cleon | | |
