2 members (Ponchogl, Gdads51), 98 guests, and 3 robots.
Topics128,128
Posts1,056,670
Members48,450
All,
I looked throughout the forum to see if these particular questions had been asked but couldn't find anything.
I removed the factory rivets from the front cross member where they bolt to the chasis to remove rust and do repairs. 3/8 bolts will go back in once they are painted and ready for reassembly. (see pic) Should these bolts be Grade 5 or Grade 8? Should the hardware holding the cross member to the chasis be Grade 8 as well? I have the Factory Assembly Manual but it does not disclose this info. It only shows torque specs.
Last question: Is there any way to decipher the part numbers that are called out in the Factor Assembly Manual. example: part number:3762206 - Bolt. I'm hoping to find out more info on that bolt! 3/8" x 2" etc.....
As always, thanks all.
1961 Chevy C10 Stepside
On my web site
Personally I always use grade 8 on any suspension items. I just consider it cheap insurance, and grade 8 hardware is far easier to obtain now than back 20-30 years ago. Sorry, can't help with the part number cyphering.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Northdm,
Your question is a good one. Grade 8 bolts should be fine in the applications you discussed. To back up my view I did a bit of research and found this in an article from "Stock Car Racing":
Grade 8 bolts are safe to use on basically every application on the racecar with the exception of wheel studs and highly loaded engine fasteners such as rod bolts, main bearing cap bolts or flywheel bolts.
I would add the following however. All fasteners, especially Grade 8 fasteners, need very flat and parallel mounting surfaces. If the surface that the bolt head face bears against isn't flat it side loads the head which can cause the head of the bolt to pop off! The reason I mention this is I will often use allen head or the 12 point type fasteners like those made by ARP http://www.arp-bolts.com/Tech/Tech.html which have a smaller head diameter and built in washer faces. Some bolts even have special spherical faces with matching washers to ensure the bolt head doesn't see any side loading from non-parallel mounting surfaces.
Also the other very important factor is correctly torqueing the fasteners. Dry vs. zinc coated vs. lubricated: they all have different torque values based on the size of the bolt and its thread type. Here is an excellent article that discusses these factors and includes a torque chart. http://www.zerofast.com/torque.htm
I hope this helps.
