0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
#566770 08/20/2009 12:06 AM
Today I replaced the tail lights on my '54 Chevy 3100. The brake lights come on when I apply the brake. The turn signals and four-ways work like they should. The problems begin when I turn the headlamps on. With the headlamps on the brake lights do not work nor do the turn signals & four ways.
I thought about replacing the flasher, but have not yet done so. Any advice / trouble shooting would be appreciated.
jfjbjr #566878 08/20/2009 4:39 AM
maybe you switched the wires in the exchange. Is it possible the turns and brakes are wired into the park light filament and you just can't see them when the headlights are on because the "park" lights are too bright?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
You might check your ground wires. I had a problem like that, it turned out that I needed to run a separate ground wire for the tail lights to the frame. Solved the problem.
Just a thought.
George
46forme #566974 08/20/2009 5:24 PM
After sleeping on it a little bit I was thinking it might be a ground issue myself. I painted the mounting brackets before I installed the new taillights on them. Like I said, everything works fine, until I turn the headlights on. After that it all goes downhill. I'll let you know how it works out.
jfjbjr #567086 08/20/2009 11:23 PM
Did your truck come from the factory wity turn signals?
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Toyvo #567098 08/20/2009 11:58 PM
Toyvo,
My truck had two different tail lights, one on each side the box, when I got it but it did not have turn signals until I converted the tail lights, so that they would also function as turn signals. I mounted a signalstat turn signal to the steering column and it worked for the past 5 years.
The only reason I replaced the existing tail lights was so I would have a matching pair.
jfjbjr #567183 08/21/2009 3:25 AM
Problem solved!! I crossed a wire when installing the new lights. Thanks for the help and tips.
