Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (Woodcmiami, newtonlr, moparguy), 613 guests, and 1 robot.
Topics126,776
Posts1,039,259
Members48,100
Most Online2,175
Jul 21st, 2025
#566991 08/20/2009 6:15 PM
I bought a 1954 GMC while on a motorcycle ride through Colorado Tuesday. It is mostly stock and mostly complete. The engine runs great.
I couldn't get it in the saddle bag of the Goldwing so I'm going back with the truck and trailer to fetch it.
I seldom checked this forum before but now that I'm a member of the Burb Fraternity I'll be checking in often. There's a lot I need to learn.
Cletis #567015 08/20/2009 8:09 PM
That is one nice looking '54 cletis - it looks pretty solid. There's nothing like getting a new toy. Too bad you couldn't have put the cycle in it and brought them both back at the same time, huh? Regardless, it should be a fun trip going to get it.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #567090 08/20/2009 11:30 PM
I like the GMC part! thumbs_up It looks like it came with at least one rear seat. Do you have plans for the burb or are or just going to see where it takes you?
GMONIZ #567096 08/20/2009 11:47 PM
Tony'N Weatherford
Unregistered
Tony'N Weatherford
Unregistered
Cletus, take a tape measure with you and measure that frame on the car-port next time you go into town. i got it out of a tf 'burb. it doesn't hurt to start planning now.
tony
#567128 08/21/2009 12:55 AM
First order of business is tires and brakes. Then I'm going to drive it as is and improve things one at a time as I go.
I've had my '54 pick up torn completely apart for over 5 years and it's still in pieces. On the '56 I went the improve as you go route. I've been driving and enjoying it when it wasn't down for improvements. That's my advice to anyone who gets a truck and has the urge to tear it to pieces.
It has what I suspect is the rear seat in the center position. Tony is talking about a center seat frame from a task force. Anyone know if it is a bolt-in replacement for mine?
Cletis #567155 08/21/2009 2:01 AM
Colorado seems to be the place for 'burbs lately. I bought mine there not long ago, and i've seen a couple more recently from Co.
Cletis #567162 08/21/2009 2:20 AM
My '54 has been apart about that long too. My Suburban gets few improvments from time to time, but most days I can drive it if I choose. I agree its a much better approach!
OldSub #567177 08/21/2009 3:11 AM
I am not sure about the task force seat, I heard they are similar but the mounting might be off. You can modify a front seat to work if you can find someone to bend some tubing for you and with a little welding it will look fine. I actually prefer the long bench seat in the middle position, it allows me to store and haul stuff around.
GMONIZ #567192 08/21/2009 4:01 AM
RJ Offline
Where in Colorado did you find that nice burb ??
RJ #567822 08/24/2009 1:47 AM
Hmmmmm. I have seen that one somewhere. thumbs_up
Very nice burb hope you have a lot of fun with it drive
I don't suffer from insanity, I enjoy every minute of it!
TPYLE #570947 09/03/2009 4:14 PM
That burb is in nice shape! It's looks unmolested, which is really nice and hard to find in a burb. Good luck with your project choices!
Cletis #1020242 04/08/2014 3:53 AM
Excuse me for bringing up a nearly 5 year old post but Peggy finally prodded me into writing a Gallery article on the Suburban. In it she linked to this post.
I just wanted to give an update on the seat questions above. The rear seat that came in it was from a '60-66. So was the middle one I got from Tony. They do not fit right in the '54. The seat that came in it was mounted on 2X10s which were bolted to the floor.
I managed to get a set of proper seats from Mothertrucker and drove the burb out to AZ and picked them up.
Click the link at the bottom of this post to see the Gallery post.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.036s Queries: 14 (0.033s) Memory: 0.6504 MB (Peak: 0.7442 MB) Data Comp: Zlib Server Time: 2025-09-22 01:42:19 UTC
Valid HTML 5 and Valid CSS
