0 members (),
170
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | Big day. Going back to the motivation thread you were all wonderful, as a result of your words, I took the engine(original) to be machined and rebuilt. While there the re-builder asked what I wanted to do about the filter. I was wondering does anyone make a spin on oil filter arrangement, where the old style assembly then goes over cartridge? Google revealed nothing. Also what do others typically do? I am sure this is not a new question so, I am also going through the search. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I assume you're looking for a modern spin on the is concealed by a by-pass filter housing? I'm not aware of any on the market. You can get a spin on filter base. I ran one of those for a while. <CLICK> Why not just put a filter canister on it like I eventually did? <CLICK>
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brand of engine (GMC or Chevrolet)? Size of engine? Year of engine? Optional 216/235/261 by-pass oil filter Tech-Tip - if you have a GMC, the plumbing (at least) will be different. High-pressure 235/261 full-flow conversion (does this work on a low-pressure 216/235??) - if you have a GMC, the technique might be different? If you have a GMC 228/248/270/302, information on the full-flow upgrade can be found at oldGMCtrucks.com | | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | Sorry, I should have mentioned it is a 283 and it is a 1958. My mistake. As for option #1, I was looking for something that looks original with the conveyance of today.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I think you can swap out the filter adapter from a later model small block to make it a spin on. I still like the oil canisters myself though. Call me old fashion. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a kit available to change over to the spin on filter on the early v-8's. It is available at many specialty shops & not expensive. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2006 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 72 | The last 283 I ran, after I got tired of messing with the old canister filter, I put on a spin on filter adapter. It required the use of a standard "Brand F" V-8 filter. I believe I got the adapter at NAPA.
Hope this helps
Willy | | |
