3 members (Napco Man, dunfire, 68ironhead), 214 guests, and 2 robots.
Topics128,081
Posts1,055,955
Members48,430
#566663 08/19/2009 5:12 PM
Big day. Going back to the motivation thread you were all wonderful, as a result of your words, I took the engine(original) to be machined and rebuilt. While there the re-builder asked what I wanted to do about the filter. I was wondering does anyone make a spin on oil filter arrangement, where the old style assembly then goes over cartridge? Google revealed nothing. Also what do others typically do? I am sure this is not a new question so, I am also going through the search.
GMCAMARO #566669 08/19/2009 5:35 PM
Ex Hall Monitor
Ex Hall Monitor
I assume you're looking for a modern spin on the is concealed by a by-pass filter housing? I'm not aware of any on the market. You can get a spin on filter base. I ran one of those for a while. <CLICK> Why not just put a filter canister on it like I eventually did? <CLICK>
Tiny #566677 08/19/2009 6:05 PM
Brand of engine (GMC or Chevrolet)?
Size of engine?
Year of engine?
Optional 216/235/261 by-pass oil filter Tech-Tip - if you have a GMC, the plumbing (at least) will be different.
High-pressure 235/261 full-flow conversion (does this work on a low-pressure 216/235??) - if you have a GMC, the technique might be different?
If you have a GMC 228/248/270/302, information on the full-flow upgrade can be found at oldGMCtrucks.com
tclederman #566683 08/19/2009 6:41 PM
Sorry, I should have mentioned it is a 283 and it is a 1958. My mistake. As for option #1, I was looking for something that looks original with the conveyance of today.
GMCAMARO #566706 08/19/2009 7:41 PM
I think you can swap out the filter adapter from a later model small block to make it a spin on. I still like the oil canisters myself though. Call me old fashion.
Builder #566715 08/19/2009 8:51 PM
Riding in the Passing Lane
There is a kit available to change over to the spin on filter on the early v-8's. It is available at many specialty shops & not expensive.
1972 Chevy c10 Cheyenne Super
Builder #566716 08/19/2009 8:53 PM
The last 283 I ran, after I got tired of messing with the old canister filter, I put on a spin on filter adapter. It required the use of a standard "Brand F" V-8 filter. I believe I got the adapter at NAPA.
Hope this helps
Willy
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
