8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible), 104 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
#565398 08/15/2009 5:29 PM
I did a search but found nothing related to this
A friend told me about a remote vacuum powered brake assist. I guess you can mount it any where on the truck and connect it to your brake system (to the hydrolic lines) and vacuum system and it will assist in increasing the stopping power without increased leg power.
I would have to change my fuel pump to a dual fuel/vac pump for it to function properly but that is probably a good idea anyway.
Anyone know about these vac activated brake assists?
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
anyone heard of this?
1953 3/4-Ton Chevy
More pix
RB53
Hydro-Vac. Mostly found on 1 1/2 ton and larger GM trucks, standard equpment on many 2 ton and larger after '55. It was an option on the 1/2-1 tons starting around 1955. It's more or less a second master cylinder with a booster on it. I've seen them mounted in various locations, usually on the frame under the cab on the passenger side rail. They can be found in salvage yards, but overhaul parts are difficult, if not impossible, to get. That's why I passed on one I could have got for $5, couldn't get parts.
A modern equivalent would be the Midland Booster. Jeg's and Summit both carry them. those are commonly used on Pro-Mod and Pro Street cars, and mount bqasically the same.
Bill Burmeister
I believe he'd be meaning the hydrovac or multi-vac units standard on the big bolts, doesn't have any connection to the fuel pump [uses intake vacuum], that double acting pump is for vacuum wiper assist
Thanks guys
Does anyone make an aftermarket remote similar to these for an upgrade?
Rich
1953 3/4-Ton Chevy
More pix
RB53
I checked out Jegs, Summit, and even Speedway, none of them list it anymore. But I did find this site that has listings for rebuilt originals. Might be worth checking out.
Bill Burmeister
Just go to a truck and powertrain shop, you can still buy the older hydro's. I just bought one identical to my 48's earlier this year but doesn't really need to be exactly the same. Go ask an expert at the truck shop,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I have a new hydro vac for sale, never been used. let me know if interested [email protected]. I bought it on ebay, but I never installed, I can send pictures.
