1 members (KEVINSKI),
160
Mod | | | Forums66 Topics128,108 Posts1,056,230 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 3 New Guy | | New Guy Joined: Aug 2009 Posts: 3 | I just rebuilt my engine. I put it back into my car and when I try to start it the starter can barely turn the engine. Engine specs: -383 Stroker (9.5:1) -462 Camel heads -Erson Cam 472 lift/306 dur. -TH350 tranny Please Advise.....
Roger P.
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Roger,
I'm ill-equipped to diagnose your engine, as I'm an older truck guy, but . . . I'll throw out these ideas anyway -
- Obvious first question: Are all your cables clean & tight?
- Are you confident your battery is up to snuff? Maybe check the voltage drop at the battery when you try to start it.
- If you pulled the plugs out (removed the compression) and tried to start it, would it spin over well? If not, I would think it would point to something being over-tight, like a main bearing or something, or maybe the clutch is hanging up? . . .
- Of course, I guess the timing could be coincidental, and your starter chose NOW to start dying . . .
Just spit-balling, here . . .
-Michael
| | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | If this is a start up of a new engine, STOP NOW!!! Do not keep slowly turning over the engine. You need this to start before all the break in lube is worn off the camshaft.
You are running plenty of break in lube , right? GM EOS, at least one bottle, and plenty of camshaft lube...
Replace the battery and cables, check all wires and circuits, and double check the firing order and timing. Double up on batteries if you have to to get this thing spinning. If it were mine, I would pull the distributor and re-prime the oil system if its been any length of time since the first priming. And if I had to crank more them four or five revolutions, I would add more EOS to the oil. Cam lube comes off pretty quick, so oil pressure is a must!
New engines MUST FIRE RIGHT OFF, read up on break in procedures before going on. You can loose the camshaft before you know it.
Joe
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | did it turn over by hand before you put it in the truck?
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Pull the spark plugs and put a torque wrench on the crankshaft damper bolt. Any turning torque over about 100 ft/lb with the plugs out indicates something inside is too tight: rod bearings, main bearings, piston/ring fit etc. If it turns over OK by hand, find the starter or battery/cable problem. Ditto on making it start immediately- - - -you can scuff a new cam by extended cranking. Once it starts, go to 2,000 RPM for 20 minutes before doing much idling. Jerry
| | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | i would hazard a guess at it being to far advanced | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Being ya stroked out that 350 ...ya might need a High Tourqe starter to spin her over ??..that is where I would go if ya know the rebuild is correct, timin right, an such | | |
