1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#56596 02/16/2006 3:58 PM
I keep reading about the good head,,what is considered the good head for the 235 aren,t all heads for the 235 from 55 to 62 the same or is there a differance if so what year and number...doc
#56597 02/16/2006 4:06 PM
the 848
#56598 02/17/2006 2:05 AM
so what is this 848 and what is it off of and what years
#56599 02/17/2006 4:46 AM
Head number is 3836848. Came on the 235. Listings show it from 54-57 and 58-62, but I have never heard of them on anything but the 58-62. Compression is slightly higher on this head.
Fred
52 3600
69 C-10
#56600 02/17/2006 12:59 PM
2 Offline
The compression is higher and the 848 head has a higher nickle content to resist cracking, a common problem with the 6's.
Tom
#56601 02/17/2006 1:36 PM
I,m wandering if these are power glyde engines,,werent the pg,s rated at more horse power???
#56602 02/17/2006 2:45 PM
doc41
I currently have 4 engines a 261 and 3 235,s one each 55/56/and57
The 55 had a powerglide on it out of a passenger car and the head casting # is 3835913
Both the others are Std.shift motors and wear casting #s 3836848 wink Regards
#56603 02/17/2006 3:35 PM
os is there a standard that the 848 head was installed on???pickup,,standard trans,,auto trans,,maybe with air cond for the extra hp??? I,m interested as I live next to a small salvage yard that is full on 40,s thru 60,s cars and trucks and going to start on a 51 chevy sport coupe for a grandson and want to install a 235 or larger chevy or gmc with 5 speed and modified inline just trying to get handle on what works to start collecting...doc
#56604 02/17/2006 3:39 PM
#56605 02/17/2006 5:14 PM
X
X Offline
I believe the 848 head came out sometime in '56, and it became the standard, and probably the one and only, 235 head, or it at least became the standard replacement head for all 235's back to '53. That assumption is based on the '58 and '68 parts manual listings, which only show that head for the '53-up 235's.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#56606 02/17/2006 11:31 PM
I like what your trying to do. If all works well, I want to build a hot rod like that with my son when he is older. My plan has been a 50 or 51 coupe with the 235 I'm taking out of my truck (replacing with a mildy built 261 I will be building soon). Best of Luck!
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#56607 02/18/2006 7:11 PM
I found my last 848 on a 1959 chevy 1/2 ton truck engine with a standard shift. The stock conpression ration for that engine was 8.25 to 1.
The head will also fit on a 261 engine but you need to drill out the steam holes, use a 261 head gasget as a template to drill the head.
Good luck on your project, please put on some pictures during your build.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#56608 02/19/2006 4:12 AM
I have a 913 casting number on my cylinder head, currently in a '50 half ton. I assume the 235 head won't fit on a 216 block? Is this a higher compression head then? How is it compatable with the 3 speed manual trans? The engine is currently not running, and haven't taken time to look for a block numeber. There are also casting numbers on the other side of the cyl. head, which are: (6?)35,918,241,570. Many thanks for your help!! Manifold numbers are 383550
#56609 02/19/2006 10:27 PM
My 56 235 has the 848 head and it is the orig head for this engine.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#56610 02/21/2006 7:13 PM
bluedot38,
You are correct the 235 head will not fit on the 216 engine. Different water pasages and side cover problems etc. However with some machine work the 216 intakes will fit on the 235 head.
#56611 02/22/2006 4:42 AM
Thanks, I plan on restoring to original, but the 235 is probably the better engine, I can not find the casting number of 3835913 amywhere, will double check my head numbers. I think the engine was just dropped in as a replacement about 30 years ago! Mike
#56612 02/22/2006 5:14 AM
I just found a site with casting numbers for heads, and I found the 3835913 numbers. It states either for the 54-55 1st series 235, or for the 58-62 235 front side mount. What is the front side mount, I am unfamilar about this. Definately have to check the block number soon! Thanks again for your help! Mike
#56613 02/24/2006 1:59 PM
bluedot38,
The head casting number for the 235 is on the top of the head next to the valve cover facing the manifolds on the drivers side. They are about 3/4" tall, can't miss them. As far as the side mount thing that was for the late engines built 58-62. You can use the late engines in swaps where you have the front frame mount by just slotting out the front engine piece just like the older engines. I hope that was clear?
#56614 02/24/2006 6:59 PM
Will look at this weekend, i think it was just a drop-in replacement engine from another old chevy truck. Gonna look for the block number, I do have the head numbers and intake numbers, correlates to a 54-55 235
#56615 02/24/2006 7:32 PM
bluedot38,
The block number to determine age of block is just above the starter. Happy motoring.
#56616 02/28/2006 1:18 PM
Question;
I have read numerous times about drilling the "steam holes" or the extra water passages for the 848 head when used on a 261 block. Since it appears that many of us have the 5913 head on 261 blocks, should the steam holes be drilled in the 5913 head just like the 848?
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#56617 03/01/2006 5:38 PM
Just found a local, who will completely rebuild my engine, new bearings, valve job,rings, oil pump etc for $750, so maybe going that route, plus he's only 1 mile down the road!
