2 members (Southerntruck, tclederman), 106 guests, and 3 robots.
Topics128,162
Posts1,056,941
Members48,458
What is the towing capacity of my '57 Suburban, with a '75 Camaro front clip (power discs), '75 camaro rear end (drums and 2.73 ratio) and a stock '75 Camaro 250ci with TH350 trans?
I guess another way of asking this would be to ask for the towing capacity of a '75 Camaro with 250ci engine!
Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
First thing to ask what is the stopping capacity. are the brakes are in good shape. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
i think if the brake's are in good shape you should be good for at least 5000 lb's .
Former Workshop Owner
Your gear ratio sounds a little too high to me for towing.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I think if you wanted to tow with it you should have left it a truck.
Camaros came with 250's?
1951 3800
-hotshoe
I like that! thumbs_up
•1952 Chevrolet 3800 pickup
---All pictures---
I presume you didn't mean front clip (fenders and grille) but instead that you have the complete drive train and brakes from a six cylinder camaro. as somebody else said you are going to be a little short on power but your stopping capabilities should be ok. I would think anything over 3-4 thousand pounds is going to be a struggle up hill. those 250 engines barely drug the cars around.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
i tow 6000 to 8000 with my 64 with a 250 in it all the time. i think more important than the engine is the gearing. if it has the front susp of the camero, i doubt it will ever be a heavy tower. good luck though.
Quote
That pretty much nailed it for me. No matter if it is a truck body and frame, you're still running Camaro running gear which limits what you can do with it.
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
I'm running the same setup will different rearend gears, it was built for go not tow.
http://s933.photobucket.com/albums/ad179/OEM54/
What is the towing capacity of a '75 Camaro with the same equipment, AND what does the truck weigh relative to the '75 Camaro. If the truck weighs more than the Camaro (it may not) I'd reduce the towing capacity by that weight.
My bet is it will be real slow with a load, and unless the trailer has its own brakes anything over a 1,000 pounds may be hard to stop.
My '55 1st GMC Suburban has a GMC 270, SM 420 4-speed, and 3.08 rear gears. The brakes at all four corners, and the rear axle, are from a '73 Chevelle. I've towed my tandem axle car trailer with it, but was not impressed by its ability to move the trailer empty, and could really feel the added load when it came time to stop. I was so impressed I cut the welded on received hitch off my Suburban shortly afterward.
I'm with Steve, best you can bet with the 250 and a 2.73 rear is about 1000#.
Thanks guys for all the inputs! It is amazing the wide range of weights I am getting! I know my 2.73 rear end ratio is not good for towing, though, but probably still OK for a tear drop trailer... Maybe a th700r4 trans would help too, with its shorter first gear and lock up converter.
I would like to (respectfully!) somewhat disagree with a couple of you guys:
my Burb will never be (and never was!)a Kenworth, but I think that a Camaro front clip does not emasculate it, on the contrary: it does give me power disc brakes (which is better than stock...), the power steering and independent suspension give easier control and the 250ci engine has more power and torque than the original 235ci engine... So I think that, as far as driving experience is concerned, my Burb is "better" than stock. I understand some people prefer all original, but I really love cruising the freeway at 70mph all day long!
I guess the 1-ton Burb with its 5.14 raer end ratio (I think) tows better, but we are now closer to a farm implement than a real highway vehicle! ;-)
A stock 1-ton panel with its low rear gears and brakes designed to stop 8,800 pounds could be safer towing a heavy trailer than your 1/2-ton 'burb either stock or with Camaro stuff. It may not go as fast and that would be part of the safety.
If you are pulling one of those tiny tear drop trailers I wouldn't expect much trouble, but you will have increased your capacity to load cargo, without having increased your stopping capacity.
The Camaro might have weighed 4,000 and was not rated to pull much of a trailer.
if your happy with it that's all that matters. i am on board with you but if you alter it to have the highway cruzing speeds you take away the pulling/towing cap. if your main goal was highway speed don't worry about the towing. i also think car front end= bad for towing, not that there's anything nec wrong with that. i personally think people worrying about stopping and disc brakes are a little overrated, but i'm cool with drivin' SLOW- not very many are.
