4 members (cmayna, Jon G, greenie-reddy, 1 invisible), 302 guests, and 5 robots.
Topics128,268
Posts1,058,395
Members48,485
#565416 08/15/2009 7:07 PM
I have my front leaf srings apart and have sand blasted them ,and now ready to paint.I was going to use POR15 on them like I did the frame .Is this a good idea or should I use differant kind of paint?
Thanks for your help.
I used it on mine, holding up just fine.
Bill Burmeister
Between the leaf is a strong friction and I can not imagine that POR15 will remain there for good. I would use paint with graphite or only graphite and paint on the face side.
Slip Plate No. 1
http://www.slipplate.com/images/pdf_datasheet/DATA-SLIP_Plate_1.pdf
'59 Apache
'67 Mustang
I used poly liner between the leaves on mine.
Bill Burmeister
....... I'd probably paint them and use the poly liners that go between them.
Por-15 and Poly Liners it is.Thanks guys
Longhorn, Be certain that your Shock Absorbers are good after doing all that to the springs. Or it may bounce you out of the cab.
1949 Chevy 6400
1931 Chevy Firetruck
On this site, under links, the Eaton Spring website guy says this.
http://www.eatonsprings.com/atqLeafFinish.htm
when exposed to sun the por15 does not hold up and the color turns to a dull non black finish
POR-15® is a high-tech, high performance rust-preventive coating designed for application directly on rusted or seasoned metal surfaces. It dries to an incredible rock-hard, non-porous finish that won't chip, crack, or peel, and it prevents rust from recurring by protecting metal from further exposure to moisture.
Use it to coat rusty frames, floor pans, farm equipment, marine equipment, or even a heavily corroded battery tray.
Quote
POR-15® is sensitive to UV light (sun) and must be topcoated for prolonged exposure to sunlight.
Topcoating is not required for areas not exposed to sunlight.
Jim & Caroline
