Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Dakota Bob, dt235sd), 132 guests, and 4 robots.
Topics128,283
Posts1,058,505
Members48,490
#564726 08/13/2009 5:49 PM
I have a 67 swb with factory over drive tranny. Where do I find parts such as the solenoid switch, governor and kick down switch?
Seems the stock rear axle ratio for a truck with this tranny is 4:11. Has any one changed it to a 3:73 or 3:42 and if so how did it work out? Most of the driving will be on the highway but I will also use it to creap around on the farm. It has a stock 283 ci. engine with RV cam.
The overdrive solenoid, governor and kickdown switch appear on ebay all the time. I am assuming you have the Warner od unit which is .73. 4.11 is a nice overdrive ratio. 3.90 is ok, but anything faster will run 100 mph down hill and die going up hill.
Google 5th avenue auto parts. They have some OD items. I have a an overdrive unit that need reconnecting but can't find anyone to do the job so its slow and go.
This is a good information to have http://webhubcentral.com/packard/maint_overdrive.htm It is actually a Packard site, but all the Borg Warner OD's work the same. I have been running overdrives 45 years and repairing them as needed. The wiring diagram applies to GM, Ford or Chrysler. Not only Packard.
This is a good information to have http://webhubcentral.com/packard/maint_overdrive.htm It is actually a Packard site, but all the Borg Warner OD's work the same. I have been running overdrives 45 years and repairing them as needed. The wiring diagram applies to GM, Ford or Chrysler, not only Packard.
