| | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 24 | I have a 67 swb with factory over drive tranny. Where do I find parts such as the solenoid switch, governor and kick down switch?
Seems the stock rear axle ratio for a truck with this tranny is 4:11. Has any one changed it to a 3:73 or 3:42 and if so how did it work out? Most of the driving will be on the highway but I will also use it to creap around on the farm. It has a stock 283 ci. engine with RV cam. | | | | | Joined: Jan 2008 Posts: 4,990 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,990 | The overdrive solenoid, governor and kickdown switch appear on ebay all the time. I am assuming you have the Warner od unit which is .73. 4.11 is a nice overdrive ratio. 3.90 is ok, but anything faster will run 100 mph down hill and die going up hill. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Google 5th avenue auto parts. They have some OD items. I have a an overdrive unit that need reconnecting but can't find anyone to do the job so its slow and go. | | | | | Joined: Jan 2008 Posts: 4,990 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,990 | This is a good information to have http://webhubcentral.com/packard/maint_overdrive.htm It is actually a Packard site, but all the Borg Warner OD's work the same. I have been running overdrives 45 years and repairing them as needed. The wiring diagram applies to GM, Ford or Chrysler. Not only Packard. | | | | | Joined: Jan 2008 Posts: 4,990 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,990 | This is a good information to have http://webhubcentral.com/packard/maint_overdrive.htm It is actually a Packard site, but all the Borg Warner OD's work the same. I have been running overdrives 45 years and repairing them as needed. The wiring diagram applies to GM, Ford or Chrysler, not only Packard. | | |
