7 members (Gdads51, Wheelie, Deegs53, 78buckshot, Peggy M, Gray_Ghost, Otto Skorzeny),
152
Mod | | | Forums66 Topics128,078 Posts1,056,024 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i want to build a flatbed with stake pockets for my newly restored 46 chevy 2 ton. i dont need it to be 100% correct but i want it to match the truck. i have looked at kampco or i think that is what its called has anyone used their products and if so how are their prices? should i just get some steel and start building, philip | | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | Also, you might try finding your local welding shop and seeing what they can do -- stake bodies aren't that hard to make and a local guy might surprise you with being able to make an original looking bed for a lot less than you think.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | I used Kampco and should have pictures of Emily's flatbed in a couple days. Cost for the steel for a 12 x 8 bed was about $650, but shipping was another $275. I'm in the process of installing the lights and should be done by weekend.
A local fabricator gave me an estimate of $3,200 last spring, so I called Kampco for the steel and bought a mig welder. The fabricator was turning away business at the time, but now he is working a skeleton crew and would probably do it a lot cheaper, so you should definitely check with any welders/fabricators in your area. | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | thanks for the info. i can do the fab work myself. i am thinking of going with the kampco stuff so it does not weigh so much the formed stuff is strong and light. philip | | |
