Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (3B, 1955 1 Series), 36 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
The temperature sending unit tube is missing from the original gauges on my 53 suburban. Does anybody know where I can pick up a replacement sending unit that would work with the original gauges. And if so, what is the best way to install it to the original wire?
Phil
52 suburban rat rod. 350/350, 9-inch ford rear, independent suspension with 2-inch drop spindles, power rack, two-tone Mexican blanket interior, paint by mother nature
The bulb and tube are filled with liquid and must be repaired by a shop. This isn't a do it yourself job. Several gauge repair shops advertise in Hemmings Motor News.
Phil,
I bet a new gauge would cost less than a rebuild-job. What is the year of your 235? 1953?
Tim
TC IS RIGHT.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
oops, the caps lock was on. you can also get the one for the V8 which will have a longer tube if you think you will ever convert to a V8. It is a little more expensive $85 at Chevsofthe40s
1953 Chevrolet 3600
Thanks for the quick responses everybody. I had a feeling that that was my only option. It's for a V8, I think I'll order that one from Classic parts. Has anybody used that V8 one before? My engine is mounted pretty low and my only concern is that the wire running from the gauge to the sender may not be long enough.
Yes the V8 one will be long enough. I put my 53 frame on top of a 73 suburban frame, so I think I have about the most distance from the gauge to the engine that you can get.
1953 Chevrolet 3600
