| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56447 02/13/2006 2:37 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Has anyone successfully upgraded a 47-50 drag link to the later style without the ball studs? I got my steering all torn down and would like to fix this while it's still apart. Thanks, Bob  | | |
#56448 02/13/2006 5:59 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I did it and I did it by using two new style tie rod ends and a tie rod. Basically I made a short tie rod to use as my drag link. It works great and it's adjustable in order to properly line up the steering wheel. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#56449 02/13/2006 7:04 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Thanks Joe. How did you rethread the shorter tie rod? Looks awfully hard to thread with common handyman type Tap & die set. Machine shop? Thanks again.  | | |
#56450 02/15/2006 11:05 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,m interested in the same setup on my 55-2. I think he means to cut down a tie rod & weld it back together & than you have the right threads on each end. I think i,m going to try it. I have a freind that is a proffessional welder/ fabricator. If its done right it should work. It,s not so much getting the steering wheel on center. Aguy can remove the wheel & put it on to line up, but I want to get the steering gear to work on the high spot. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#56451 02/16/2006 7:07 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Good point Wrenchbender Ret. That's what I was really refering to when I said "center the steering wheel". I needs to be centered on that "high spot" so the truck will go down the road straight and hold the road with no shimmy or wobble. The adjustable drag link will give you the ability to get that wheel perfectly centered. I wrote Shipwright an email and told him that I had threaded a short tie rod after cutting the right hand thread end off, but could not find the exact size die. It appears to be a 13/16" die and when searching could not come up with one. Finally, I used a 3/4" die and that will work. The other idea, as you stated, would be to cut both threaded ends off of a tie rod and weld them back together at the desired length. That way, of course, you get the exact threading you need. In either case, the adjustable tie rod style drag link with tie rod style ends will add just that much more controlability to the vehicle and I think you will find it to drive significantly better. Joe
#56452 02/16/2006 3:42 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | ''Has anyone successfully upgraded a 47-50 drag link to the later style without the ball studs?''
yes see: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=003275;p=1#000000
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#56453 02/26/2006 10:06 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Finally got the job done and wow, what a difference. I upgraded the tie rod ends and made my own adjustable drag link per Jim's (Caroline'sTruck) part #'s from NAPA. Thanks for all the help guys. I didn't know how badly the front end parts were worn till I got it all apart. All the ball studs were egg shaped and had gouges in the necks from overtightening the end caps. I also installed a sway bar. This upgrade is awesome. No more lean in turns. They say not to install the sway bar on lowered trucks but it works well when you just install shorter bolts in the end links. I took a ride this morning and it was an absolute pleasure to drive. NO MORE SHIMMY! I love it. I got new king pins for it, but it drives so nice I don't think it needs em.  | | |
#56454 02/26/2006 11:10 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | v ~ glad to hear of your success.
my pins were so bad (.025'' play) i had to redo them.
what/ where did your sway come from...?... that's next for me.
#56455 02/26/2006 11:23 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Got the sway bar from Chevy Duty. The instructions were a little weak but I got it figured out. Let me know if I can help at all. Thanks again, Bob  | | |
#56456 02/27/2006 11:22 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,m glad it worked for rest of you. I found out it won,t work on the 55-2 up. It uses different ends for the drag link than the tie rods.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#56457 02/28/2006 12:27 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | these do also WB-R. That's why you will have to have a Chevy taper cut into the steering and pittman arms that are different from the stock 'tie rod cross or long bar' ends. You may have to have the holes welded up (pittman & steering arm) after you remove the ball ends (if that is what you have as I'm not that familiar w/ 55/2) a bit to redrill them for the new taper cuts. The new chevy tapers will match the new tie rod ends (see link for part #'s) and provide a snug fit.
