0 members (),
47
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I did a quick search and didn't see anything on the subject of engine heat in the cab. My truck engine seems to put a lot of heat into the cab. My a/c unit tries to fight it, but it is, in my opinion, losing the battle badly. I have about two layers of the bubble stuff covered in aluminum foil on each side on the fire wall, plus a thin layer of batted insulation. All the holes are plugged, but the problem is bad. It almost seems like there is a hole in the firewall that it is coming through, but there is no hole. Before the 261, the 216 wasn't quite as bad. That makes sense to me, since the 261 is a bigger engine, but I don't know what to do with it or what might be may be the real good stuff to use. Thanks for any help!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | how thick is the insulation? Is your heater core shut off?
| | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Joe...I had a similar issue in my '42 1/2t. I felt heat when I drove the truck, even with the windshield cranked open. What was preplexing is that my firewall was not warm/hot to the touch...by process of elimination we found that the heat was coming up through the openings in the floor from the exhaust system. I insulated the floor and for the most part solved the problem. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | My friend had the same problem.....
A 53 1/2 ton with a V8...It was awful. Turned out he was getting a load of heat sink from the exhausts. He spent a bit more time (and money) on good insulation on the whole floor including under the seat and the firewall. Making sure there were no openings or gaps.
It made a big difference,mind you we don't have to deal with the same kind of ambient air temps you guys are dealing with. It could be you're getting quite a bit of radiated heat through the roof as well. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Ahhh. Engine heat. I wrapped my headers with lagging. In fact, I used 60 feet of lagging just on the headers for the 216. I also wrapped my exhaust all the way back, as I am a spaz. I am ready for the salt flats!
It has made a noticeable difference in the underhood temperature. I guess it must be cooler in the truck as well, but I drive with the windows open, and the side, and cowl vent as well. Plus, I don't live in texas.
I have the stock firewall pad, and a heavy felt pad and rubber mat on the floor. I don't know if that helped at all.
If you do wrap the headers/exhaust, the best tip I can pass along, is to soak your lagging in a bucket of water before you wrap it on. Plus, when you start 'er up you get the feeling you are in a Stanley Steamer.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think you need to explain this "lagging" MrLang - exactly what did you use that withstands exhaust temps? doubt there's many steam fitters here  Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Probably means this stuff.
Bill Burmeister | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | There is no heater in my truck. I have never had one. The exhaust is a possibility. I just had new aluminum head pipes put on the truck. The insulation is a total of about one inch thick on the firewall. I may need to beef that up, but I'm going to look at the floor,also. The truth is, the firewall insulation never seemed to make any difference. I have the doors and cab sealed up pretty well and is it seems better - definitely quiter! There has to be a product that will keep that heat turned back - I just got to find it. Thanks for the suggestions, everyone!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Here's a pic of the lagging. http://i221.photobucket.com/albums/dd45/HomeCrafter/IMG00212.jpgNowadays, its made of woven fiberglass. The discoloration was caused by the VHT paint underneath burning off. Supposed to be good for 1500 degrees. Guess it gets hotter under the lagging than I thought. With the "mummy" conversion, I can drive on the highway for an hour, stop, and put my hands right on the headers. For that matter, the pipe all the way back, as it is wrapped as well. | | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Generally speaking, the coatings make the pipes look pretty, but don't hold the heat back as much. Fiberglass lagging is as effective as asbestos. Do a search, there is a land racing forum, lots of discussion over there about this stuff. Enclosed streamliners have these problems all the time. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks Bill, I forgot to mention this stuff as well. As an added benefit,it can also improve performance too. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I have the same problem in my 37 and I just have carpet glued on the firewall,opening the cowl vent usually gets rid of the problem when its hot and keeping it closed when its cool gives me heat since I have not installed the heater. | | | | | Joined: Jul 2009 Posts: 12 New Guy | | New Guy Joined: Jul 2009 Posts: 12 | Found this stuff from DEI (not the NASCAR company). I haven't tried it yet, still too far away on my bolt for details like this, but I have an uncle who uses it on his '69 Camaro and swears by it. More pricey then JEG'S, but for some that doesn't matter. http://www.designengineering.com/products.asp?m=sc&cid=3 | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | When my dad originally rebuilt my '51 he installed a shut off valve on the heater hose so that there was no residual heat given off by the heater core. Closed it in the summer, opened it in the winter.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Try driving a COE. It can be 45F outside and its all you can do not to sweat, with the windows and winshield cranked open.  | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 |
