I think I already know the answer, but here goes....
I was told when buying this truck that it was on a '76 chevy frame. After looking at it closely, I believe it is the original frame with a '76 chevy rear end, and cross member/suspension. If you look at the following pics, could you tell me what you think. It seems to me that the cab mounts and spring mounts are not '76 style, and the factory rivets that hold the cab mounts on are intact.
I didn't think it was possible to mount a suspension from another truck without cutting the frame, and these frame rails appear uncut.
Lastly,
I really don't like the way it is lowered (I believe it's on drop spindles), and I'd like the wheels under the fender wells in front. Basically, I want it to look like it came from the factory with the tall skinny tires, sitting up higher----but with a MUCH better ride than the original suspension. Is there a way to do this? Will a mustang II suspension with regular spindles keep the ride height original yet give a good ride? Could I graft on an S10 frame in front?
ALso, since it appears the original rear springs are in the truck. WHy does the modern rear end sit farther back in the fender well?
Sorry for all the questions---eager to learn. Here's the pics:
http://inlinethumb19.webshots.com/43730/2355125590104021666S600x600Q85.jpghttp://inlinethumb54.webshots.com/43125/2903632920104021666S600x600Q85.jpghttp://inlinethumb49.webshots.com/21680/2069016390104021666S600x600Q85.jpgThanks,
Jason
