3 members (Rusted Nut, dgrinnan, UtahYork), 336 guests, and 4 robots.
Topics128,162
Posts1,057,057
Members48,463
#555050 07/12/2009 11:55 PM
So I got sick of trying to get the tie rod ends on My 52 apart and than got it all blasted and went to install the new parts and there I am with this BIG screwdriver putting the new parts in the tie rods I thought there has to be a better way to do this the book says to screw it down to stop and than back it up to the frist pin hole , so I built a tie rod tool today and it made it go great .
Took a 19 mm 3/8 drive sockit and cut a pc. of 3/16 steel same width as the tie rod end bolt to fit in the slot and as long as the inside of the sockit + 3/4 inch than took the steel pc.slid it into the socket and weilded it to the sockit on the two sides and now all I gotto do is use a 3/8 rachit and adjusting and replacing tie rod and control arm ends parts are EASY.
http://s559.photobucket.com/albums/ss39/sparky52/tool/
Pete
Pete52 #555126 07/13/2009 3:33 AM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
thumbs_up I have made several tools over the years & it sure does beat the snot out of paying the bigg bucks for a tool you may use just a few times in your lifetime..Joe
#555131 07/13/2009 3:42 AM
Cool.
But in case anyone isnt feeling inspired, I bought a set of drag link sockets from Sears for $20 awhile back.
Click
My 1953 Chevrolet
1947.1 Gallery
Would have never thought of looking for a factory tool , well it keep Me busy and I got to use the tools .
Pete
Pete52 #555503 07/14/2009 5:34 AM
I was in the same position you were and very accidentally found them. Otherwise it would have been me with the screw driver and a set of vice grips adjusting the darn things. grin
My 1953 Chevrolet
1947.1 Gallery
I hope you are wearing safety glasses while using your impact with your home made tool or any other tool with a impact.
62 Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #555663 07/14/2009 10:42 PM
Don, who mentioned an impact wrench? headscratch
My 1953 Chevrolet
1947.1 Gallery
I wear My safety glasses whatever I do anything in the garage I have spent 45 years working in constuction and have had My share of eye injuries and I know Myself I will see somthing that needs to be done and just start doing it , so now I just put them on right away so no more trips to the doctor .
Thanks , Pete
Pete52 #562520 08/06/2009 5:13 AM
I'm in construction too and after having an eye doctor dig a piece of rusting metal out of my eye (it wasn't rusty before it went in!) I am a fan of safety glasses. I found a set at the local CarQuest store with two LED lights - one on each side of the frame. Now I can see where I am looking when under my truck without all that stuph falling into my eyes from the years of accumulated road grime! Cool tool! Wish I held the patent!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
Craig,
As a bit of a joke, a few months ago I also bought safety glasses with two swivel-adjustable LEDs. They are no joke - they are extremely useful. No longer are drop lights needed when working inside the engine "compartment" of my COE.
I found the glasses when looking on-line for bi-focal safety glasses (most people need reading glasses after 40 years of aging).
Tim
bifocal safety glasses
This style is inexpensive and does not drop off at any head angle
bifocal safety glasses with two adjustable LEDs (not inexpensive - maybe a good Christmas present/hint)
Moderated by  MNSmith
