0 members (),
118
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | I need some help identifying the purpose of a cutout in my '52 3/4 ton heater/defroster (arrow "A" in photo). Also, what's up with the exposed slats (arrow "B" in photo)? I'll have to look closer, maybe defrost outlet was moved??? Thanks all! Photo is here! Thank you! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It looks like the outlet has been moved. Can you post a photo of a frontal view of the heater?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | been butchered fer sure I think "A" is where a ranco valve mounted, the brackets, one with the hole and one with the peg, would be where the control cable mounts, the bent flanges beside the hole would be where a component clicks in - "B" looks to me to be just additional warm air out when it's on full defrost position, I doubt they'd put louvers like that under the defrost outlet, and they do look factory somebody appears to have re-shaped things where the e-brake handle musta been pinching their fingers against it, and they obviuosly wanted more heat on the drivers feet, choppin a hole in the end like that .... I'd be lookin for a new case! Bill | | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | Thanks red58. As long as I can get heat out of it, it doesn't matter to me what it looks like. I like warm feet too! | | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | been butchered fer sure Bill Bill, Talk about being butchered, check out what's on the other side of the firewall! "What would you call this???". | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hahahahaha - I'd call it a 55-57 car heater fan and some very creative ducting - makes me think the heater is from a car as well, a make-do farmer who also liked warm feet  iI wouldn't be suprised if the inside heater is a 55-57 car, not the right shape for any year truck heater I'm familiar with, but it does have similarities to the one that was in a 57 sedan I had unless you're planning on using the truck on the farm, I'd strip alla that stuff off, inside and out, and find a more correct heater, there's some that work quite well Bill | | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | ...I'd strip alla that stuff off, inside and out, and find a more correct heater, there's some that work quite well
Bill Suggestions please!!!!! Tim | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a post in the parts wanted section here for a 47-55 heater, particularly a deluxe version could turn one up - there were heaters made back then specifically for the praire farmers, had seperate fans for cab heat and defrost, and a variable temp control .... could also look at modern aux truck heaters, smaller and neater like these or maybe these .... would better reflect on your abilities and taste when the neighbors admire the truck  of course new aftermarket would need 12v for the fan, but changing either the truck to 12v or the fan motor to 6v is easy enough Bill | | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | Thanks Bill. Hey... I added another photo at the bottom of the page. Do you know what the lever that the arrow is pointing at is for? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | another cable connection, the clamp above the arrow point holds the cable housing, the peg is where the cable end loop connects .... there's yet another cable connect setup at the left side of that pic - those are both prolly from the original installation in whatever it came from, the car had some fresh air controls, and the air input ran along the inner fender from an opening at the front next to the rad - prolly the installer tried to copy the same arrangement with that 'custom ductwork'
Bill | | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | I moved the levers while the blower was on. The one on the left lets the air in from the blower, but the one on the right didn't have any effect. I'm thinking it might divert it past the heater core. | | |
