7 members (Thomaslb, 1955 1 Series, Hanks custodian, Ridgeback, Hotrod Lincoln, Ponchogl, 1 invisible), 46 guests, and 2 robots.
Topics128,090
Posts1,056,031
Members48,433
#560438 07/30/2009 1:23 PM
I see some are going to the shock absorber looking tube to replace the springs on their hood. Any info on what to buy would be appreciated.
Are they called struts?
gazim #560455 07/30/2009 2:30 PM
They are called Struts, where did you see them installed? I might be interested in trying that too.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
You are a heck of a lot of help. Now we both are looking.
I really need to know the length needed
I'll post it if I find it elsehere.
gazim #560939 07/31/2009 10:44 PM
ODSS President
ODSS President
Ok, on my '49 the same springs have been working fine for 60 years. You want to replace them with something that wears out in a few years? I have replaced several on wife's and friends cars. I just don't see an advantage. Also is the hood itself rather heavy for these struts to last very long?
~ Cosmo
1949 Chevy Half Ton
Cosmo #561020 08/01/2009 3:39 AM
Given that both the springs and the hinges affect how the back of the hood aligns on an AD truck, I wouldn't try to put struts on there unless you also replaced the hinges with something else.
Paint & Body Shop moderator
If they ain't broke...don't fix them! thumbs_up
I considered this swap, but had reservations about the hood alignment too.
The only thing I don't like about the original set up is the noise they make! eek
More pix on Flickr.
jockbolter50 #561353 08/02/2009 12:55 PM
After much head scratching I have decided to scrap the idea. The hinge effects the hood alignment as some have noted. I could be done but would entail a lot of re-engineering. Sorry 53M, if you get it figured out let me know.
gazim #561448 08/02/2009 8:16 PM
I
I Offline
good luck trying to align your hood with struts on. I took my springs out becuase I did not like what it did. Just use a prop
iceburgh #561449 08/02/2009 8:21 PM
My luck I would be at a show with clumsy people and have a lawsuit on my hands when the prop was kicked.
gazim #561636 08/03/2009 11:49 AM
I think it was Tiny that used gas struts from a Ford Taurus for his. They are not hard to install.
Ya the struts will work but you have to have a different hood hinge. The stock hinge lifts and shifts forward when opened.
Any Ideas? I still would like to use them.
gazim #561694 08/03/2009 4:44 PM
Please be aware that struts do NOT work well when the tempature drops. If you drive when it is below 55 degrees or so, they will not hold up the hood. They are not safe in cool/cold weather. Ask me how I know--
Glenn
How do you know? yahoo
