4 members (Gray_Ghost, Shade Baby, WarEagle1, Jon G), 114 guests, and 2 robots.
Topics128,102
Posts1,056,184
Members48,436
#56018 02/03/2006 5:25 PM
The # is 1352-065
http://www.5speeds.com/t5 says it's from an '84 Mustang/Capri?
I understand thet I still need an S10 tail section but what about the ratios?
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
#56019 02/03/2006 8:32 PM
Will that T-5 bolt up to your bellhousing? The S-10 T-5 will.
Joe smile
#56020 02/03/2006 8:40 PM
The seller advertises it as an S10-S15 transmission?
But I could NOT find that # in the inliner's T5 page.
#56021 02/03/2006 11:33 PM
Riding in the Passing Lane
Measure the mounting hole spaceing & the collar diameter where it goes into the bellhousing & T.O. brg. I don,t think it will fit.
1972 Chevy c10 Cheyenne Super
#56022 02/04/2006 1:27 AM
I believe I would be more inclined to buy a T-5 that reflects the correct number to fit an S-10 or S-15. I think that way you can be sure of what you are getting. It's a pretty good job to install the right one - no telling how hard it could be to install the wrong one.
Just my 6 sense!
Joe smile
#56023 02/04/2006 1:43 AM
I put one in my 63 about a month ago behind a 230, and I love it. However, I agree with Joe, get one from an S-10...my install was enough of a pain in the @$$ without chasing a bunch of adapters to get it crossed over from a Ford case. My next challenge is to re-build my T-5 after driving it for a while. I didn't do anything to it but pick it up from a junk yard, put fluid in it and stick it in the truck. Apparently it was well trained by the PO...it changes its own oil!
One other pointer...unless your truck has a whole lot more room in it than mine you'll have to straighten the shifter out a little bit or it will hit the bench seat when shifting into 2, 4, & R. Solution is either change to buckets or judicious application of a BFH with a little heat (not too much or you'll damage the shifter).
Daily Driver 63 C-10 LWB Fleetside
