5 members (klhansen, 55shaker, SammyC60, Gray_Ghost, TUTS 59), 134 guests, and 2 robots.
Topics128,101
Posts1,056,523
Members48,448
#559370 07/27/2009 7:14 PM
Hi all, I am wondering if anyone knows where I can get a replacement bearing assembly for the bottom of my steering box.it is called a lower worm gear roller bearing. the only place I have found them is in a kit thats pretty expensive when I only need one bearing
56 stepside 3/4 ton longbed
I looked in to this before deciding to buy a couple of bearings for for my '41-'46 box. Go about 1/2 way down the page to the one piece bearing replacement. Looks like '41-'59 use the same bearing, which is the same as the tractor bearing here,
http://davistractor.com/ushop/index.cgi?ID=PWO5I0&task=show&cat=MF%2dSteering+%26+Front+Axle
How about this from the Filling Station
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z58359~P17.50~~~~S2PJ14RE1E69151511224M~Z5Z5Z5~Z5Z5Z50000014x
so youre saying
Part 5BC/760906M1 - ROLLER BEARING, STRG. SHAFT (Mfr.#5BC)
5BC/760906M1---Roller bearing, use with 181365M1 shaft. (Mfr.#5BC)
is the same as steering box lower bearing assembly?
This is the part number, Part 8N3571-52, its suppose to be a direct replacement for the bearing and race.
The link from the filling station has just the bearing for $17.
Not sure why the links are not acting right, but you can copy and paste.
Joe
Joe H. you did it! They had the bearings I was looking for. Thanks for the help. trucvk will be way easier to drive w/o crushed bearings in the bottom fo the steering box.
case closed
