0 members (),
103
Mod | | | Forums66 Topics128,095 Posts1,056,494 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | Hi all, I am wondering if anyone knows where I can get a replacement bearing assembly for the bottom of my steering box.it is called a lower worm gear roller bearing. the only place I have found them is in a kit thats pretty expensive when I only need one bearing
56 stepside 3/4 ton longbed
| | | | | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | I looked in to this before deciding to buy a couple of bearings for for my '41-'46 box. Go about 1/2 way down the page to the one piece bearing replacement. Looks like '41-'59 use the same bearing, which is the same as the tractor bearing here,
http://davistractor.com/ushop/index.cgi?ID=PWO5I0&task=show&cat=MF%2dSteering+%26+Front+Axle
How about this from the Filling Station http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z58359~P17.50~~~~S2PJ14RE1E69151511224M~Z5Z5Z5~Z5Z5Z50000014x
| | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | so youre saying Part 5BC/760906M1 - ROLLER BEARING, STRG. SHAFT (Mfr.#5BC) 5BC/760906M1---Roller bearing, use with 181365M1 shaft. (Mfr.#5BC) is the same as steering box lower bearing assembly?
| | | | | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | This is the part number, Part 8N3571-52, its suppose to be a direct replacement for the bearing and race.
The link from the filling station has just the bearing for $17.
Not sure why the links are not acting right, but you can copy and paste.
Joe | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | Joe H. you did it! They had the bearings I was looking for. Thanks for the help. trucvk will be way easier to drive w/o crushed bearings in the bottom fo the steering box.
case closed
