2 members (Hanks custodian, 66flea), 197 guests, and 5 robots.
Topics128,078
Posts1,056,049
Members48,433
I have a 46' 216 4 speed that I would like to convert to an automatic while keeping the original engine
but you can't bolt a 350 turbo to the 216
any suggestions as to how to proceed
Rick
3B Offline
Hy rick boyd, if you could find all the parts for a 53 hydramatic, I think that would be a fairly easy swap. As to more modern transmissions, there are adapters available to make it a bolt on proposition, you would have to deal with the rear axle/driveshaft issue also.
Go to Stoveboltengineco.com, Tom has a super adaptor system that will allow the modern automatic to fit the 216/235 motors.
1946 1/2-Ton Chevy
