| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 25 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 25 | I have a 46' 216 4 speed that I would like to convert to an automatic while keeping the original engine but you can't bolt a 350 turbo to the 216 any suggestions as to how to proceed
Rick | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rick boyd, if you could find all the parts for a 53 hydramatic, I think that would be a fairly easy swap. As to more modern transmissions, there are adapters available to make it a bolt on proposition, you would have to deal with the rear axle/driveshaft issue also. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Go to Stoveboltengineco.com, Tom has a super adaptor system that will allow the modern automatic to fit the 216/235 motors. | | |
