7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl),
112
Mod | | | Forums66 Topics128,049 Posts1,055,665 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | All,
My 250 is running hot, gets to about 235 sitting idling. Cools down a little from that on highway.
New water pump, gauge/sender, failsafe tstat, original radiator was tested/flushed at shop, original fan, no shroud, belt is tight, timing is set, carb is new/rebuilt. Fan is a little far from the radiator, going to put a spacer in.
Any ideas?
I may take to a radiator shop and have them do a leakdown test. The motor has gotten hot a couple of times briefly, maybe blew a head gasket?
I have no idea on the history of the engine.
1949 5 Window 3100
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i dont know if the 250 has a pet cock on the drivers side near the rear of the block or not. if it does remove it and see what comes out. ive had to rod out and flush the blocks on all my trucks in that location. pretty nasty stuff comes out when you start to get it to come out. i like to catch as much as i can. im suprized at how big the pile of crap can get during the process. | | | | | Joined: Feb 2000 Posts: 5,200 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,200 | Head gaskets going bad will either use coolant and steam out the tail pipe (smell to), or blow coolant out of the radiator overflow. Pull the radiator cap when the engine is at idle and watch for bubbles (not the monkey!) in the coolant.
Fan should be in the 3/4" range from radiator core.
Sounds like air flow problems, since it cools down when moving. I assume you are using stock pulleys? Plugged radiators generally heat up out on the road and can't get rid of the heat through air flow. A lean carburetor will also heat up a engine pretty fast along with a plugged exhaust system.
Get a infrared heat gun and check the thermostat housing, block, head, and radiator to get a idea of true temp of the coolant. Also get a candy thermometer in the neck as a back up. You should see no more then one or two degrees above T-stat temp.
Mine reads about 20 hotter then it really is using the OEM hole between #1 and #2 cylinders. I moved the probe to the T-stat housing and now the gauge read actual coolant temp, 190 right on the money. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i don't know what yoear your truck is but the 250 i put in my 64 ran hot in the summer and towing for 2 years. not as hot as yours but it could creap over 200 sitting at a light. when i would pull a long hill the temp would climb, when i would go down the other side with the truck pushing the engine it would cool down. the orig 6 rad tested ok but i switched it out for a new v8 one and that took care of it. no more fluctuations at lights or hills. | | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | Bumping this up.
As far as head gasket, no smoke, no antifreeze in the oil, no bubbles. It does overflow though. When it gets to 230 or so and you turn it off, the coolant is boiling in the overflow bottle (and howling).
I have a heat gun and my gauge and sender are ok.
1949 5 Window 3100
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Meyer,
I sure don't know the particulars on your situation but 99% of all heating problems stem from a radiator that has plugged tubes. A radiator shop can flush and boil till hell freezes over and those tubes will still be plugged....it comes with age. The radiator is where the rubber meets the road, if it's not transferring heat the whole equation doesn't work.
HEY...a birthday cake! KOOL...
Stuart
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | as stu says and my thoughts are you say you got the rad flushed gettin' flushed is NOT gettin' rodded. in other words have the radiator cap removed and the shop will run a flat bar down each tube making sure all tubes are fully open, so flow is at it's maximum rate. then re-install it. a wet/dry comp test should be able to tell you if you have a head gasket problem.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I am going to assume that the temp drops to normal when driving on the highway. If so, then it sounds like air flow. the best fan/shroud/radiator installation has the fan a minimum of 1/2 its hub diameter away from the radiator core, followed by a shroud that comes as close to the blades as possible. Moving the fan close to the radiator only moves air in the donut area where the blades are.
your description of no shroud and fan far away from the radiator means that the air is simply swirling around the blades and not moving thru the radiator. if at idle, a piece of card board can not be held against the radiator face by the air, you simply do not have enough air flow.
My recommendation is to simply add a fan shroud, and do not use a spacer. build the shroud to come out to the fan. If you do not want to do that, then remove the engine fan and go electric. with what you described, the fan is doing nothing more than robbing power and making noise.
If on the highway you are not running at the temp your thermostat is, then in addition to air management issues you have either a plugged core, or bad water flow.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Try taking the stat out and replacing it , there are alot of bad stats out there and it is cheap and easy to do, any time I have problems with a new install on a engine and have heat problems it has turned out to be a bad stat the quality control is just not there anymore .
Pete | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I bit the bullet on my 235 and bought a new aluminum radiator and it made the world of difference. i had mine back flushed and rodded and wasted enough money to pay for the new radiator. ron got it here.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Get a new radiator, cools down when driving sounds like a bad radiator. Thermostats are cheap, so get a new one to go along with the radiator.  | | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | Update... when I last set the timing, I had the vacuum line attached to the distributor still, causing incorrect timing. Reset it, runs at 175 to 190 now, fixed.
1949 5 Window 3100
| | | | | Joined: Sep 2009 Posts: 7 New Guy | | New Guy Joined: Sep 2009 Posts: 7 | i dont know if the 250 has a pet cock on the drivers side near the rear of the block or not. if it does remove it and see what comes out. ive had to rod out and flush the blocks on all my trucks in that location. pretty nasty stuff comes out when you start to get it to come out. i like to catch as much as i can. im suprized at how big the pile of crap can get during the process. 51 Ashton, I amwondering if u can give me more info or a pic on this petcock. My father has a 250 chev (dont know hat year) in his boat that is continuously overheating. We have rulled out everything else except the engine. We are installing a new water pump but thats all we can think of- no water in oil or smell so we think the head gasket is good. We did notice that in the coolant lines was a lot of crud from the water cooled manifold so alot of that could be in the engine. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Howdy,
Here's yet another vote for the rad. On a '75 C-10 I used to own, I went through all the same stuff with the 250. I had the rad done and still no success. The only thing that fixed it was a new one, and it was a stock 2 row for the 6 cyl! It didn't look like much, but it worked like a champ!
best wishes,
Les | | |
