8 members (delky, val, UtahYork, Otto Skorzeny, mason86, Bill Hanlon, Woodcmiami, 1 invisible), 60 guests, and 2 robots.
Topics128,030
Posts1,055,424
Members48,422
#556555 07/18/2009 3:57 AM
Apprentice
Apprentice
I am thinking of doing something different while I am savine money to buy the wheels I want to put on my '50 AD. Dodge trucks come with 20" spares and my question is can I fit an 8" wheels on my truck with a 225/35/20
Try an 8.25X20. That way it will look like a truck instead of a gangbanger's pimpmobile!
While the tire size should physically fit in the fenders, you will have difficulty in finding wheels that will bolt up. Most, if not all, of the 20" rims on the market in the correct bolt pattern are meant for late model trucks, whcih have the incorrect backspace to work on the early trucks. You'll either be looking at adapters or custom backspace wheels in order to fit them.
A couple words of of caution, you will lose ride qualtiy and load capacity with that size tire. They are very stiff due to the short sidewall. They are also not load rated due to the primary use as a passenger type tire.
Bill Burmeister
LONGBOX55 #556565 07/18/2009 4:25 AM
Apprentice
Apprentice
Jerry I can see you live by your quote
Bill I know i will lose ride quality but its only a temp thing until I can buy the wheels I want. As for load I'm not going to be hauling anyting in this truck.
You can pick up some free to cheap original type wheels and even tires if you ask around..
Can't imagine what you're saving up for..
Grigg #556570 07/18/2009 4:52 AM
Apprentice
Apprentice
I'm saving up for these Wheels
http://www.hobbycar.com/JohnD2008b.jpg
Ahhh....spoked wheels. My favorite.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
They're doing them in 20" sizes now? I imagine they'll be pricey!
More pix on Flickr.
Wheels don't effect ride quality. On the load capacity, you'll need to make sure that the tires are rated to carry at least the weight of the truck plus passengers. I've seen tires fail due to not having proper cpacity to carry even the empty truck. In one particular case, low profile tires on a 3/4 ton '72. All 4 tires failed within a month. The tires were intalled at the customers request, even though he was warned that they were insufficient load cpapacity.
Please use caution, and make sure of the capacities and also maintain proper tire pressures, as they might need to run higher to carry the load.
Bill Burmeister
Apprentice
Apprentice
[quote=jockbolter50
[/quote]
No the 20's are just a temp thing I will be running 15" spoke wheels when all is said and done
A few questions. Why are you wanting to run 20s if you're plan is to go with 15s? Question #2, If I re-read the original post correctly, are you planning to use Dodge 20" rims? If so, unless you have altered the axles, they will not bolt up. I don't beleive the backspacing will allow for it even if the pattern has been changed. You would be ahead just running 15" stock type wheels, using them to get the truck setup properly for the final tire/wheel size. Much less cost as well.
Bill Burmeister
LONGBOX55 #557128 07/20/2009 1:22 PM
[quote=LONGBOX55][quote=Laid_Out_50]
Beg to differ, I am running 20' with 45 aspect and they ride very poor. In Mich. Where they think potholes are a necessary evil for living in a state with 4 seasons,I jar my teeth every time I get the truck out.
Laid Out 50, Sorry I thought you meant 20" Wires! dang
More pix on Flickr.
gazim #557323 07/21/2009 1:36 AM
It's not the wheel that's causing the bad ride, it's the short sidewall. Go to a taller aspect ratio sidewall, and the ride quality will improve. The wheel itself has little to no effect on the overall spring rate. Same goes for ply rating, heavier the ply rating, the stiffer the ride.
Bill Burmeister
if you have a 3/4 ton or 1 ton with 8 lugs, look for some 19.5 rims. i found a set in the boneyard off an old milk truck,they looked cool on my old 66 4wd with snowies all around!
62 mark #557957 07/23/2009 3:52 AM
Apprentice
Apprentice
1. I plan on running 20's just to get a rise out of people something different.
2. Yes they will be dodge 20" steel wheels, axles have been changed and will us an adapter plate
The final 15" tire size for my truck is .09" in height shorter than the 20" tires
Apprentice
Apprentice
here's you a pic of a 52 on dodge steel 20's.
52 pics
here's my 56 panel project with same wheel.
56 panel
'56 panel project
