| | | Forums66 Topics128,266 Posts1,058,369 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | I know this is to new for the bolt page, but I thought I would ask anyway. My father-in-law has a 2005 GMC truck and the brakes squeel when you start to back up. It is very anoying to say the least. He has had it to 3 different shops and everyone says the same thing, Thats the nature of GM trucks. Does anyone have a suggestion on what I could do to stop the squeeling? The truck only has 25000 miles on it and the pads look new. Thanks in advance. | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy elm [51 Basket case], try making a few medium to hard stops in reverse from five to ten miles an hour, and see if the noise changes or goes away. I assume that truck has four wheel disc brakes, is that correct? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 1/2 ton or 3/4-1 ton? 1/2 tons are rear drum for that year, 3/4-1 tons are 4 wheel disks. I've never heard of one doing that with either system as a "normal" thing. Is the noise coming from front or rear? Could be as simple as dust buildup in the rear.
Bill Burmeister | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Dirt/dust between the disc pad & the caliper is causing the squeal. Take them apart & clean, then add some anti-squeal shim's between the pad & caliper along w/some Silicone brake grease in the contact area's....Joe | | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Sorry about that. It is a 1/2 ton two wheel drive. Can you get the shims from the local flaps store or do you have to get them from GM? Thanks for the replies guys. I will try your sugestions ZooKeeper. Thanks again. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | I know at least at my auto parts house you can buy the shims by themselves...Joe | | |
