0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#55598 01/26/2006 5:16 AM
Junior Member
Junior Member
just thinking would it be posible to put 2 carburetors on a 305 v-6 motor? does anyone know who might make a manifold for this motor or a adapter plate for the 2 barrel manifold that i have? just looking for something different! maybe even a set of headers
#55599 01/26/2006 6:51 PM
That would be the GMC engine, correct? What would be the purpose (besides different) of adding fuel to a low RPM engine such as this? This is a brute for torque but not for speed. Additionally I don't think anyone makes aftermarket manifolds for the Jimmy engine so it is a moot point.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#55600 01/27/2006 4:54 AM
If you haven't discovered it already, go to Jolly's site for the details on the 305. http://www.6066gmcguy.org/performance.htm
As for an intake for dual carbs, you would have to make one. And like moneypit said, the 305 was made to pull heavy loads at low speeds. If you want to run it wide open on the highway, it won't last. If you're going for performance, a V8 will make you a lot happier.
Fred
52 3600
69 C-10
