7 members (Flint48, Red75bronco, 78buckshot, Leo, wvstovebolt, TUTS 59, 1 invisible), 88 guests, and 3 robots.
Topics128,129
Posts1,056,697
Members48,454
#555054 07/13/2009 12:05 AM
Hey guys, I wanted to know if any of you could point me in the direction of where I can order some mustang II rotors in a larger bolt pattern? Every company online only seems to have 5 on 4.5 or 5 on 4 3/4. I need some for 5 on 5.5 .
If not do you think it would its cheaper just to buy a set and get them redrilled for the size i need?
Also can these rotors be ordered from your local parts store or are they special order rotors?
Thanks, Slim
slim rides low
It might be an idea to contact someone like
Master Power Brakes and enquire about this.
Most of the ones I've seen are in the smaller F*rd and Chevy patterns.
I would doubt your local FLAPS would carry something like them.
It may also not be possible to re-drill the rotors due to their construction.
Maybe that's why they only seem to be available in the smaller sizes.
Hopefully someone will prove me wrong!
More pix on Flickr.
Hopefully! Im trying to avoid going with wheel adapters.
slim rides low
Thanks Jockbolter, it seems that im going to use adapters. I just have to find a company that makes them hub centric or with a torque ring.
slim rides low
Why the 5 on 5? Got a certain wheel you want to use or something?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Scott
I have the same question. Might be easier to find wheels for the smaller bolt pattern. Or see if you can find spindles that will accept the larger GM style brakes instead of the M2 parts.
Bill Burmeister
Yeah guys. I took the plunge and bought some wheels that are 20"s and they have the big bolt pattern. I wanted them to give my AD a retro look with a 20" steel wheel with the GMC center cap. One thing I learned is that when you go custom nothing is ever just plug and play.
slim rides low
Where did you get the steel 20s? I've seen the Vintique painted steel look ones but they are still billet (expensive!)
I like the idea of painted steels and caps but with the large diameter..
More pix on Flickr.
