1 members (TooMany2count),
81
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Hey guys! I'm new to the group, all the way from Calgary Alberta! I'll try to get my truck on here soon. I just got it, it's a 61 Apache Fleetside half ton, long box. It's got the original 283 in it, but someone once swapped out the 3 on the tree for a 4 speed on the floor. It works well, except sometimes it seems to get stuck in gear. If I shut the truck off, it pops out into neutral no problem. Does this mean my clutch is worn? Any feedback would be awesome. Thanks! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Is it a car trans or a truck trans? Scott | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | You may not have any freeplay left in the clutch adjustment. That could mean a new clutch. Start by seeing if you can play with the adjustment and see if that helps or hurts the situation. Report back. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | With the hydraulic clutch slave, it could also mean that you're having issues with it.
I'd check and adjust the clutch linkage, and check the hydraulic line and the master cylinder to make sure there's fluid in it.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | It's a trans out of a 3/4 ton, so i was told. | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | This seems like a dumb question, but I'm a bit of a newbie....how do I check the adjustment? Or, how do I adjust the clutch freeplay? | | | | | Joined: Jun 2009 Posts: 15 New Guy | | New Guy Joined: Jun 2009 Posts: 15 | Don't forget the pilot bushing. When they get dry/worn the tranny will be hard or nearly impossible to shift.
Wenco Ind. Driveshafts VAn Nuys, CA Est. 1967
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | it shifts good most of the time, unless I use the clutch alot, holding it down alot, like when 3 point turning the rig into a parking stall. Got stuck in second at church the other day and stalled on me, ha ha! I have a feeling the slave cylinder's screwey, maybe leaks past the piston. Whaddya think? | | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | I would think if the slave leaks past the piston you would feel the drop in the pressure on your pedal similar to brakes loosing fluid or pressure. I am not 100% sure of that though. My slave cylinder actually leaks fluid on to the ground, I have no trouble shifting.Do you have a manual? 11-2 explains 2 adj.pedal total travel(bumper adjustment) and pedal free travel. I could scan and send out page for you although I don,t know if that will solve anything. Ask Woogaroo.Or Scott | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | I don't have a manual...but yes, the pedal seems to lose pressure, it becomes softer if held down too long. Ken, nice truck!! Kinda inspires me to keep mine.
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | The Slave Cylinder for the clutch system resides on the bellhousing. It takes about 20 minutes to rebuild it and then reinstall it. I had to do this on my 61 a couple tears ago. I just pulled it off, ordered a rebuild kit, and put it back in.
The kit consisted of a seal and a new piston. It was like 3 pieces, very simple. Kit was $15 and a new cylinder was $70ish...
That is where I would look. Make sure to bleed the system when you are done...air in the lines = not working!
Also when you bleed the system...put on some eye protection...the system builds a good amount of pressure and the fluid really makes your eyes sting!!
Good Luck,
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | That's definitely gonna be my plan of attack Kyle. Except that mine is mounted on the inner fender behind the oil filter. Possibly because it used to be a 3 on the tree? Is bleeding a clutch done the same way as bleeding brakes? | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I had to do this on my 61 a couple tears ago.
Also when you bleed the system...put on some eye protection...the system builds a good amount of pressure and the fluid really makes your eyes sting!! That explains the "couple of tears"
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | You absolutely need to get a shop manual. They show up on ebay all the time. They're being reprinted, and the prices for good originals are nearly what they are for the reprints. I took my time and lucked out, getting an original in perfect shape, for $6 plus shipping. The manual is for '60 model, carried over for '61, and then the '62 is a thin supplement to the '60, so I had to find both.
The return spring on the clutch arm should run up to a small bracket on the frame, but the slave cylinder itself should bolt to the bellhousing. If it really is bolted to the frame, you need to change that.
Also, I discovered something very interesting when I pulled my engine--the clutch fork rides on a pivot ball inside the bellhousing. That pivot IS removable. The pivot ball is about the diameter of a nickel, and is obviously a ball. However, on my truck, after 45 years, it had worn down to a sharp little point! No ball, just a round little pyramid. I have no idea how it even worked anymore. Check that out too. It takes a whole lot more effort to get access to it though. But it can be done without removing the engine--you'll just need to gain access from below.
-Brad
SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jan 2009 Posts: 21 Apprentice | | Apprentice Joined: Jan 2009 Posts: 21 | The four speed also came in 1/2 tons. my dad has a 62 1/2 we bought from the original owner and it has the "granny" 4, my nephew also has a 60 apache he just bought and it also has the original six with the "grannie" [email protected] | | |
